Alberta 0 #51 Posted May 20, 2025 What is a field that's required I'm not savy Share this post Link to post Share on other sites
953 nut 66,038 #52 Posted May 20, 2025 @Alberta, click on this link and do your own post introducing yourself and letting us know what kind of problem we can help you with. https://www.wheelhorseforum.com/forum/47-introductions/ Share this post Link to post Share on other sites
dray@georgiarays.com 0 #53 Posted June 30, 2025 HI, Last night, my tractor stopped when out of gas,and I failed to turn OFF the key for 30 minutes. When I did turn it off, I tried to start, but NOW there is NO Spark.Thus, Did I damage & burn out the coil? Is there a place to purchase a new one? It is Yellow, with the condenser on top mounted? It WAS only 30 minutes, but it is very old. PLEASE Help me, if you can. Thank you Chef Danyell Share this post Link to post Share on other sites
lynnmor 8,827 #54 Posted July 3, 2025 (edited) On 6/29/2025 at 8:04 PM, dray@georgiarays.com said: HI, Last night, my tractor stopped when out of gas,and I failed to turn OFF the key for 30 minutes. When I did turn it off, I tried to start, but NOW there is NO Spark.Thus, Did I damage & burn out the coil? Is there a place to purchase a new one? It is Yellow, with the condenser on top mounted? It WAS only 30 minutes, but it is very old. PLEASE Help me, if you can. Thank you Chef Danyell Sorry, I missed this posting, it would be better to post a new thread in engines or electrical. Do you still need help? I have never seen a yellow coil, and the condenser should be mounted on the air filter support. If you go to the top of this thread most of your questions will be answered, I would start by following the troubleshooting in the Onan Service Manual that is available there. Photos would be a big help. Edited July 3, 2025 by lynnmor Share this post Link to post Share on other sites
dray@georgiarays.com 0 #55 Posted July 15, 2025 On 6/29/2025 at 8:04 PM, dray@georgiarays.com said: HI, Last night, my tractor stopped when out of gas,and I failed to turn OFF the key for 30 minutes. When I did turn it off, I tried to start, but NOW there is NO Spark.Thus, Did I damage & burn out the coil? Is there a place to purchase a new one? It is Yellow, with the condenser on top mounted? It WAS only 30 minutes, but it is very old. PLEASE Help me, if you can. Thank you Chef Danyell I FOUND the issue as a 25 amp fuse LOOKED fine, but it had blown, in the lower part, invisible to the eye, so I gambled replacing it, and it works.! HOWEVER, I have a PROBLEM: The ignition switch DOESN'T ENGAGE THE STARTER. I'M Forced to JUMP IT, each time to start. What might be the issue-and it's a new ignition switch? Could there be an issue with the Solenoid-like a 'DEAD SPOT'. It's over 20 years old, but I don't want to replace it and have it STILL not work? Can you PLEASE Help me? Chef Danyell Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,233 #56 Posted July 15, 2025 Do you know the model number or year of your tractor? Share this post Link to post Share on other sites
Handy Don 16,588 #57 Posted July 15, 2025 If you can jump the solenoid to start the tractor, then both it and the starter are ok. Do you have a volt meter and the skill to use it? If no, find someone who does? If yes, then... Tractor in Neutral, wheels chocked... Carefully (probably with a helper) test to see if there is 12v on the “S” terminal of the ignition switch when the key is turned to “Start”. If no (since the tractor runs if jumped) then likely a bad switch. If yes, carefully test at the solenoid for 12v when the key is turned to “Start”. If no, then wiring from switch to solenoid is bad. 1 Share this post Link to post Share on other sites
Dan Manning 0 #58 Posted August 30, 2025 Hello all ; My wheelhorse has a strange problem . Starts great and cuts for about 20 minutes and the stops . I check and no spark . If I let it sit for 4 or 5 hours it starts right up and repeat . I think coil but interested in advice . It is 2 cylinder Onan with 8 speed . Thanks Share this post Link to post Share on other sites
lynnmor 8,827 #59 Posted August 30, 2025 5 hours ago, Dan Manning said: Hello all ; My wheelhorse has a strange problem . Starts great and cuts for about 20 minutes and the stops . I check and no spark . If I let it sit for 4 or 5 hours it starts right up and repeat . I think coil but interested in advice . It is 2 cylinder Onan with 8 speed . Thanks Likely the ignition module behind the flywheel is failing with heat. A coil can act the same. Go to the beginning of this thread and you will get all the answers (good and not so good) that are available. Check on eBay for aftermarket kits that contain both parts, Onan original parts are priced high. Share this post Link to post Share on other sites
