Ed Kennell 43,816 #1 Posted September 1, 2014 I need to paint the chutes on several blowers. What is the current opinions on the best coating for a low friction surface ? Has anyone used a bed liner coating? I will be brushing. Share this post Link to post Share on other sites
cheesegrader 434 #2 Posted September 1, 2014 Mine is valspar tractor implement rattle can spraypaint with spray teflon coating applied at the start of every season. I'm not happy with it. It sheds snow OK, but little gravel stones have chipped and pitted the paint badly. I'm thinking about POR 15 the next time it is redone. Share this post Link to post Share on other sites
AMC RULES 37,251 #3 Posted September 1, 2014 Not liner, lots of texture there, so too much resistance. POR 15 maybe... or this stuff, I know it is hard as nails. http://www.eastwood.com/engine-paint-kit-27084.html?reltype=2&parent_id=26939 Share this post Link to post Share on other sites
Martin 2,133 #4 Posted September 1, 2014 powder coat them and lots of wax on the paint. if you can't get them powder coated, still use wax on the paint you do put on there.... Share this post Link to post Share on other sites
boovuc 1,090 #5 Posted September 2, 2014 Wax on.....Wax off! Wax on........Wax off! I even used ski wax which held up much better than automotive wax. And the ski wax I used rubbed on. (Just like my old downhill ski's before my body told me that it would shut down if I kept doing that crap)! 1 Share this post Link to post Share on other sites
Geno 1,930 #6 Posted September 2, 2014 I plan on soaking mine with spray silicone before every use. I do this with other things and am intersted to see how it works. Has anyone else tried it? Share this post Link to post Share on other sites
Trouty56 567 #7 Posted September 2, 2014 I was reading this thread for tips and thought about a product I use on my firearms called Fluid Film....can spray it on bare metal and it will prevent rust for a long time. Has lubricating properties also.....I got an old fruit grinder I sprayed it on (claims to be food grade) and when I crushed grapes for wine this year the juice beaded up on the metal and wood parts. Might hold up well in a snowblower/snowblade application..... Share this post Link to post Share on other sites
shallowwatersailor 3,216 #8 Posted September 2, 2014 Has anyone tried a good application of EZ Slide graphite paint? Share this post Link to post Share on other sites
Navig8r 132 #9 Posted September 2, 2014 I've heard of many uses for Fluid-Film... many swear by it for all sorts of stuff... Probably worth a try! I want to mount a thin sheet of HDPE or PTFE inside the chute of my WB blower.... no rust, sacrificial when stones hit it, and relatively slick! Share this post Link to post Share on other sites
Ed Kennell 43,816 #10 Posted September 2, 2014 I found this Paint that I used to coat the underside of a deck about 5 years ago and it held up real well, so I thought I'd use it on the chutes. It gets super hard and really gloss y. I'll still give them a good coat of wax. Share this post Link to post Share on other sites
Geno 1,930 #11 Posted September 2, 2014 You just gave me an idea Ed. When I saw the grey I thought of the epoxy on my shop floor, it's indestructible. Also, don't even think of walking on a wet spot or you'll find yourself on the floor. 1 Share this post Link to post Share on other sites
Ed Kennell 43,816 #12 Posted September 2, 2014 Concrete floor coating is one of the uses listed for the paint I used and there is a caution to add sand if it is used for this purpose. Share this post Link to post Share on other sites
Geno 1,930 #13 Posted September 2, 2014 Mine said the same, but you can't mop or use a floor scrubber on a floor that has sand in it. The urethane is great but not like the epoxy. It is actual 2 part epoxy that you mix, the color and the activator. Share this post Link to post Share on other sites
holler1 4 #14 Posted September 3, 2014 (edited) AMC rules mentioned POR15. I painted the lower part of my 36" RD deck with POR15 to stop the rust, but it seems to be very effective at shedding grass. I'll attach a picture if i can. I've been mowing with it all summer. I took it off and replaced it with a newer deck. When i turned it over, there was no grass stuck underneath- none. Edited September 3, 2014 by holler1 Share this post Link to post Share on other sites
holler1 4 #15 Posted September 3, 2014 http://lh6.googleusercontent.com/-anF4GGRgqiU/VAejkvtwPhI/AAAAAAAAFzs/EYHFlibPgwA/s1024-no/IMAGE_1.jpg Share this post Link to post Share on other sites
Fun Engineer 860 #16 Posted September 4, 2014 I wonder if the product made by rust oleum called Never Wet would work on the chute? Geno, try a mop head like this one. It works great on my epoxy floor with non-slip in it. 1 Share this post Link to post Share on other sites
AMC RULES 37,251 #17 Posted September 4, 2014 The Never Wet stuff is amazing stuff... but doesn't last very long, ain't cheap either. Share this post Link to post Share on other sites
Geno 1,930 #18 Posted September 5, 2014 (edited) I wonder if the product made by rust oleum called Never Wet would work on the chute? Geno, try a mop head like this one. It works great on my epoxy floor with non-slip in it. I have a mop bucket for spot cleanup like yours, but my floor is smooth, it works great. I put 2 coats of epoxy on it in 97 when I built the shop, the 2nd coat makes it really shine! The only thing was after doing 2 coats back to back on 3500 square feet it made me really high. Usually we get out the big self propelled Clarke floor scrubber 3-4 times a year to make it like new again. Matter of fact it was due a few months ago but I've been too bust chasing Horses! I'll try to get a pic of that monster on here the next time we get it out which should be soon. Edited September 5, 2014 by Geno Share this post Link to post Share on other sites
dbartlett1958 99 #19 Posted September 6, 2014 Has anyone tried a good application of EZ Slide graphite paint? John, Yes I have. I did my Toro walk-behind blower with the EZ Slide. I did one half of the auger with it, and half without. Guess what. The half with the EZ Slide plugs up way easier than the stock paint. Stick with wax or POR. Share this post Link to post Share on other sites
can whlvr 994 #20 Posted September 8, 2014 living in a snow belt I use my thrower a lot,i spray it with an industrial silicone spray and it works great Share this post Link to post Share on other sites
