Jasen
37'' deck belt size
Jasen
I have been trying to find this for an hour now with no luck. Does anyone know how or where I can find the belt size and part number for a 37'' deck belt?
gwest_ca
300 and 400-Series tractos
If all the idlers a V-idlers you need a 6-sided belt #111178
If 1/2 the idlers are flat you need belt #110265
Drive belt charts
Dimensions are on the last pages
Garry
dcrage
Jasen
Don't have the answer for the size and # for your belt. I get mine from Toro.
What I do want to tell you to check on is that there are two different belts for the 37" deck. Some 37" decks have a 6 sided belt (2 v pulleys on the mule drive) and others use a normal v belt (1 v pulley, 1 flat pulley on the mule drive).
(Gary types faster than me)
Edited by dcrage
Jasen
Thank you very much!
Jasen
Wow! they are not cheap belts! I hope it last a while.
