David Hart 0 #1 Posted August 31, 2014 (edited) Can someone please post the wiring diagram for a WheelHorse chager 12 Model 1-7231, with a push button ignition and a generator light. Edited August 31, 2014 by David Hart Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,987 #2 Posted August 31, 2014 The wiring diagram in this 1967 model 1277 manual should be the same as your 1968 early production Charger 12. They both used the K301S-4712b engine with starter/generator and battery ignition. The original ignition switch is # 7263 and it replaced the 4988 switch used in 1967. Here is a picture of the back of it. This 7263 switch is a heavy duty switch that will handle the high current required by the starter. If you have a push button starter I suspect the ignition switch has been replaced with a standard light duty switch and the push button handles the high starter current. The 7263 switch is still available from Toro but expensive at over $50. Many now use a stardard battery ignition switch plus a starter solenoid to carry the high current. Both would be about the same cost but accomplish the same thing using more common parts and likely last longer. Garry Share this post Link to post Share on other sites
