Akestner 36 #1 Posted August 27, 2014 Ok awhile back I got a rockshaft from Kelly and put it on my 520h I've been looking for a single bottom plow got to talking to a neighbor and he gave me 2 plows but the problem I'm having is it will either pick up the plow enough to get it off the ground and not enough do dig in the ground and if I adjust it so it will go in the ground it won't lift it high enough to get it out of the ground I'm pretty sure everything is hooked up correctly any suggestions Share this post Link to post Share on other sites
squonk 44,686 #2 Posted August 27, 2014 I have seen rock shafts that have the arms positioned at different places. Perhaps you need a different rock shaft. Or a different length chain to the clevis hitch. Pictures would help Share this post Link to post Share on other sites
Don1977 605 #4 Posted August 27, 2014 You should be in the end hole in the last picture. That will give you more lift. Share this post Link to post Share on other sites
Akestner 36 #5 Posted August 27, 2014 Thanks I've got it going now Share this post Link to post Share on other sites
