Geno 1,932 #1 Posted August 26, 2014 These are some parts I brought home about a month ago, just now looking at what was there. I knew what a lot of it was but not these. 2 Frames and a mower deck. One frame looks like a sort of RJ, the other, I haven't seen this combo of pedal and lift. Thanks for the help. 1 Share this post Link to post Share on other sites
CasualObserver 3,417 #2 Posted August 26, 2014 well, the deck shell appears to be a 1960 RMR-32 deck. That's the only one I can think of that had the runners like that. There should be a little hole on the back side between the two flaps sticking up, that's where the lift rod connected. The stripped frame appears to be the matching Suburban that went with the deck... so I'd say either a 400/550. And the other frame looks to be like a 1962 something to me... so 502/552/702. I'd lean toward 502 by the shift decal placement and switch hole plug. 2 Share this post Link to post Share on other sites
Geno 1,932 #3 Posted August 26, 2014 It does have a hole in the back between the flaps, you're good. Share this post Link to post Share on other sites
Racinbob 13,290 #4 Posted August 27, 2014 Please tell me that you flicked a bugger in the 5 gallon bucket and I'm not really seeing parts painted green. 1 Share this post Link to post Share on other sites
Geno 1,932 #5 Posted August 27, 2014 Uh yeah, it was that. 1 Share this post Link to post Share on other sites
