Countdown To Christmas!
Geno
More ID help please
Geno
These are some parts I brought home about a month ago, just now looking at what was there.  I knew what a lot of it was but not these.  2 Frames and a mower deck.  One frame looks like a sort of RJ, the other, I haven't seen this combo of pedal and lift.  Thanks for the help.  :)
post-13404-0-34682900-1409073405_thumb.j
post-13404-0-43390700-1409073416_thumb.j
post-13404-0-72403900-1409073431_thumb.j
post-13404-0-82235400-1409073443_thumb.j
CasualObserver
well, the deck shell appears to be a 1960 RMR-32 deck. That's the only one I can think of that had the runners like that.  There should be a little hole on the back side between the two flaps sticking up, that's where the lift rod connected. The stripped frame appears to be the matching Suburban that went with the deck... so I'd say either a 400/550.   And the other frame looks to be like a 1962 something to me... so 502/552/702. I'd lean toward 502 by the shift decal placement and switch hole plug.
Geno
It does have a hole in the back between the flaps, you're good.  :text-+1:
Racinbob
Please tell me that you flicked a bugger in the 5 gallon bucket and I'm not really seeing :wh: parts painted green. :naughty:
Geno
Uh yeah, it was that.
