thomas1
C120 deck
thomas1
I recently acquired a C120. On the discharge side of the deck is a round bar, maybe 3/8" diameter.
6b310d3300552d169462222121282b59_zps512d
I assume this bar is to support the chute opening and meant to attach across the bottom of the deck. It is loose on the front end end and I believe it tore away from the front edge of the deck. Here.
12ca14bc8c863b99296398a37640ef86_zps1a42
Am I correct in my thinking? It's current location is less than optimal for letting grass exit the chute. :)
oldredrider
Your assumption is correct. Just weld it back to the bottom of the chute.
thomas1
Perfect, thanks.
