Shadow56 0 #1 Posted August 25, 2014 need recommendation for repair facility for 1978 200d hydro Share this post Link to post Share on other sites
pfrederi 18,660 #2 Posted August 25, 2014 Are you planning on taking the whole tractor? Or are you removing the hydro pump and hydro motor. If you remove the parts you cold try a local hydraulic repair facility. (The guys who fix the hydro systems on garbage trucks, snow plows etc.) Be advised parts for the sundstrands in the D series are hard to find and very expensive. The hydro place may not want to bother with the job. I would talk to them first. Do you know what the problem is?? It may be a control linkage issue not something wrong with the pump/motor. What are you symptoms? Share this post Link to post Share on other sites
