Navig8r
Tire chain installation/fit
Navig8r
So I've never used chains, but I have a set, new in the box, but old, of the correct size, 4-link, for my 416-H
I went to put them on for some extra traction for pulling chores around the yard....
How loose should they be without using anything to snug them?  I put them on and they were really loose!
Tires are fully inflated, so I'm not too sure whether they are the right chains, or maybe mis-packaged?
Any advice?
Thanks in advance!
KC9KAS
I usually let a little air out of the tires and get the chains tight, then air the tires back to pressure making the chains really snug.
With use, chains will stretch...especially new ones.
When mine start getting loose, I use a couple of short tarp straps to keep them tight.
I keep them tight enough that they don't "sing" while driving.
bowtieguy
Really loose????......better take KS's advise or they will wipe out the plastic fan that cools your hyro (inside near right wheel)..new fan will cost more than rubber straps!!...just sayin'.....or ask me how I know! :scratchead:
Navig8r
Rally loose!
Sent from my ADR6350 using Tapatalk 2
AMC RULES
Just need a bungee to take up the slack.
Edited by AMC RULES
Navig8r
So that's cool then?  I guess they can move around a bit, but the bungee will keep the slack from slinging about, wrecking stuff?
Hossenfeffa
The other variable in the equation is that not all tires that are supposed to be the same size are. That is to say, a 23x10.5x12 from one manufacturer, will differ in actual size from another manufacturer. Same with the chains!
AMC RULES
Also, you can customize the fit of your chains with a simple tire chain tool.
You can find 'em cheap, all over ebay.
Different sizes available...typically, this is how they work.
shallowwatersailor
This is true! I have a set of rubber chains for 23X10.50-12 tires that I cinch up three links on Titan turfs and just cinch them on Kenda turfs. They are the same sized tires but the Kenda tire is about one inch taller.
Edited by shallowwatersailor
Bach-Ed
Years ago (late 1960s) my father decided WH chains were too expensive.  He got a set of VW bug chains(the original bug) at Warshawski's and they were a good fit (after we shortened them).  And they were a lot cheaper.  So creative persons might want to find alternative sources
  • Similar Content
    • morePEdal
      By morePEdal
      *16 HP Onan Engine, 665.4 Hours
      *8 Speed Transmission
      *48” Snow Plow- Works Great! Set up and READY TO GO BEFORE THE SNOW!
      *Nice 42” Mowing Deck, no rot or welds, smooth spindles
      *OEM Wheel Weights, 50 lbs. Each
      *Chains
      *Valves adjusted this summer, runs great!
      *Good battery
      *Tires All Hold Air
      *LED lights all the way around
      *Manuals included
      Bought a Honda tractor with 4WD and 4WS with deck, plow and snowblower so I don’t need this tractor.
      Cash Only!
      *WILL NOT RESPOND TO “IS THIS STILL AVAILABLE?”
      *COMING SOON:  Also selling a Wheel Horse 520H with a 2-Stage Snowblower. Check out that listing if you want a snowblower garden tractor!
    • swarfeater
      By swarfeater
      using the 312-8 to spread some driveway gravel with the blade and something interesting happened. a tire chain snapped a crosslink came around twisted up some sheetmetal and the rear fender then ripped a slice through of the fuel tank. it all happened in about 1/10 of a second so no reaction time. check your chains once in a while i guess ??
    • Geno
      By Geno
      There's another thread on here talking about tires used in snow removal, Mike (Sparky) mentioned that the turf tires work better. That threw me for a loop but you guys know better than me, I haven't used any of this equipment yet.
      I have a steep hill that comes up to my place and I have chains but I would rather not use them if possible,(unless there is ice underneath I will have no choice). The drive and lot is all blacktop.  I will be puting a snow blower on one tractor and a plow on another.  I also have a few sets of 50lb each weights, and some 20lb each front weights.  What have you guys found to be the best combination to use?
