JamesC-120
Tecumseh H60 rebuild
JamesC-120
I need to find an undersized rod and over sized piston and rings for my H60. Does anyone know where to find them?
Thanks
KATO
These guys may have a ring set ...you might want to phone them or e-mail them
http://www.mowtownusa.com/Tecumseh-Engine-Part-34855-RING-SET-010_p_86672.html
the piston and pin are apparently still available at .010 over size. item number  14  33313B Piston & Pin Assy. (.010 oversize)
http://www.jackssmallengines.com/Jacks-Parts-Lookup/Model-Diagram/tecumseh/92616/11559
There are aftermarket rods available in std size only Tecumseh part num -31380C you will likely have to get your crank throw built up with chrome and ground down or find a good crank somewhere
