squonk 47,782 #1 Posted August 17, 2014 I bought Ezra from the original owner last fall. I plan on putting the tall shoot blower on this winter. With the cooler temps we've been having it's gotten me to thinking about winter duty and getting the Horses ready. I wanted to upgrade the lights with Sylvaina Silver Stars and new reflectors. The lights on this tractor worked and this is what I found after removing the lens and bulbs. The grass DID NOT fall into the sockets! Here is a thread when I did the same upgrade to my C-160 2 Share this post Link to post Share on other sites
Digger 66 3,530 #2 Posted August 17, 2014 Chirp , chirp , chirp . Share this post Link to post Share on other sites
chazm 413 #3 Posted August 17, 2014 Mike its simple electric 101... You turn on the switch ,A spark ignites the grass & then you have lights.... .... 5 Share this post Link to post Share on other sites
squonk 47,782 #4 Posted August 17, 2014 I should put grass in my Tecky engines then. I love a good fire! 1 Share this post Link to post Share on other sites
Geno 1,931 #5 Posted August 18, 2014 Nice job on the reflectors squonk, what did you use? Share this post Link to post Share on other sites
squonk 47,782 #6 Posted August 18, 2014 Click on my link in the first post Share this post Link to post Share on other sites
AMC RULES 37,259 #7 Posted August 18, 2014 Won't you need spark to start a fire? 1 Share this post Link to post Share on other sites
Racinbob 13,087 #8 Posted August 18, 2014 Oh geez!!!!! I must show restraint. All sorts of comments about sparks and fires are going through my head. I've got an A/C unit to fix today. I better get started on it so I get my remaining brain cells headed in another direction. Share this post Link to post Share on other sites
Zeek 2,299 #9 Posted August 18, 2014 What is the reflective material you put in the lenses? Is that from another headlight? Share this post Link to post Share on other sites
squonk 47,782 #10 Posted August 18, 2014 Reflector material is from some lights at work. I should bring a piece to the show and cut off chunks. See the link I left in the first post Share this post Link to post Share on other sites
AMC RULES 37,259 #11 Posted August 18, 2014 Two chunks over here please. Share this post Link to post Share on other sites
squonk 47,782 #12 Posted August 18, 2014 Pictures after the bulbs were installed. These were taken with the engine off. The last one was with the engine running and I took a heat reading on the lens. Topped out at 122 deg after 5 min of run time. I noticed the temp jumped to 135 deg when the engine was turned off from the exhaust heat and no fan to blow the air. I did another test after cool down I turned the lights on for 5 min with no engine and topped out at 115 deg. Share this post Link to post Share on other sites
AMC RULES 37,259 #13 Posted August 19, 2014 How many lumens are they putting out? Share this post Link to post Share on other sites
squonk 47,782 #14 Posted August 19, 2014 My lumen meter is at the cleaners 1 Share this post Link to post Share on other sites
AMC RULES 37,259 #15 Posted August 19, 2014 You mean you're meter lumen? Share this post Link to post Share on other sites
