biggin 37 #1 Posted August 15, 2014 Has anyone changed from points to the electronic ignition on their single cylinder kohler? I went to my local dealer to get some "tune up" supplies and he said that they haven't sold too many point sets lately and guys are upgrading to the ignition module instead, not having to clean and adjust points isn't a big deal but upgrading to this doesn't sound too bad. 02' DL never finished Share this post Link to post Share on other sites
kudzu3 323 #2 Posted August 17, 2014 Sounds interesting, waiting on comments. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,838 #3 Posted August 17, 2014 I think you will find they will only replace the points in a magneto ignition. And then they only work if there is one magnet in the flywheel. Two magnets and they won't work. Garry Share this post Link to post Share on other sites
illinilefttackle 399 #4 Posted August 18, 2014 I went this way when I rebuilt my K-301 6 years ago-never looked back!-Timing staying the same -good performance-Al http://kirkengines.com/index.php#PointSaver Share this post Link to post Share on other sites
formariz 12,352 #5 Posted August 19, 2014 Has anyone changed from points to the electronic ignition on their single cylinder kohler? I went to my local dealer to get some "tune up" supplies and he said that they haven't sold too many point sets lately and guys are upgrading to the ignition module instead, not having to clean and adjust points isn't a big deal but upgrading to this doesn't sound too bad. 02' DL never finished I have one on a k91 powering a RJ. Right from installing it the difference was obvious. Engine stars much quicker usually on first pull if there is gas in bowl. Timing is also automatically set and stays that way. Nothing to wear. OVA 2, Mega-Fire and OEM Kohler Electronic Transistorized Solid State Ignition Modules [Return to a previous section] There is absolutely no difference how these modules work. They all work the same. Kind of like the difference between the Chevy, Dodge and Ford vehicles. These are universal and high-performance. They improve engine performance by stabilizing the spark, much like crank trigger ignition does. The NOVA 2 and Mega-Fire modules have a durable die-cast aluminum housing. They all produce a hot spark even at cranking speeds, allows the coil to produce 100% voltage. Weather-proof and very reliable. Ignition timing is automatically set. No kick-back and no timing adjustment required. Works excellent with virtually any magneto ignition coil! Suitable for use with most 2 leg or 3 leg magneto coils and with a flywheel having one or two magnets mounted internally or externally, and with coil mounted underneath or outside of flywheel. Works great regardless of the polarity of the magnets, too. Works on most lawn mowers, chain saws, trimmers, garden tillers, snow throwers, brush cutters, one or two cylinder outboard boat motors, etc., with points and condenser ignition. But will not work with most Stihl trimmers and chain saws. Usually, the coil don't need replacing when substituting the points and condenser with one of these solid state modules. If the engine ran, then the coil is obviously good. Works only with magneto type ignition coils originally connected to contact points and a condenser. They will not work with solid state ignition (CDI) coils, battery ignition coils or with flywheels having a ring of magnets mounted internally to which the ignition coil (mounted underneath flywheel also) operates off of, such as the bigger aluminum block Tecumseh engines (8hp and up). (With the module, as each magnet passes the coil, it'll produce a spark. And if the spark don't occur at the precise time with the piston at a certain position in the cylinder, the engine will either "kick back" or will not run.) If the magnets for the charging system won't interfere with the magneto coil(s), then these modules should work well. But if the magneto coil(s) operate off the same magnets for the charging system, then neither module won't work. The modules senses when the magnet passes the coil and that's when it makes the spark. If a bunch of magnets continually pass the coil, then the coil will produce an array of sparks. How the timing is automatically set and how it works: First of all, with points, the point gap determines where the ignition timing is set (on systems with a fixed or non-adjustable ignition coil). Therefore, the spark occurs when the magnet in the flywheel passes the coil laminations the moment the points open. But with no points, the magnet still passes the coil laminations at the same moment, which sends an electrical current through a transistor and circuitry within the NOVA 2 module. This current is sent in the form of a signal to the module; within, a transistor opens the primary circuit in the coil and the spark occurs. All this happens at the speed of electricity. The conventional points and condenser ignition system is less responsive. Each module has two wire connections. One wire connects to the ignition coil and the other wire connects to the ground of the engine with use of a supplied mounting screw. Comes with detailed instructions. Click here for installation instructions. Share this post Link to post Share on other sites
biggin 37 #6 Posted August 19, 2014 Thanks for the info, I've got a 73' 16hp Kohler, so it should work for me I hope, several years before they went to cdi 02' DL never finished Share this post Link to post Share on other sites
rmaynard 16,689 #7 Posted August 19, 2014 Thanks for the info, I've got a 73' 16hp Kohler, so it should work for me I hope, several years before they went to cdi 02' DL never finished If I read the above info correctly, it only works on magneto type, not battery ignition. Share this post Link to post Share on other sites
formariz 12,352 #8 Posted August 19, 2014 (edited) If I read the above info correctly, it only works on magneto type, not battery ignition. Correct, it does not work with battery ignition. Should have mentioned on last post, this information is from Brian Miller's site. Greatest source of information anywhere for Kohler engines. Edited August 19, 2014 by formariz Share this post Link to post Share on other sites
biggin 37 #9 Posted August 19, 2014 Thanks guys, I was led to believe by the salesman that it worked on all points and breaker motors, good to know it only works for magneto engines. 02' DL never finished Share this post Link to post Share on other sites
JC 1965 1,534 #10 Posted August 19, 2014 I went this way when I rebuilt my K-301 6 years ago-never looked back!-Timing staying the same -good performance-Al http://kirkengines.com/index.php#PointSaver I went with this also on my K-301 several years ago. The point saver works great and David Kirk is a great guy to deal with. 1 Share this post Link to post Share on other sites
Terry M-(Moderator) 2,267 #11 Posted August 21, 2014 Tried it on my pull start HH60...could never get it to work ..... Share this post Link to post Share on other sites
rick 258 #12 Posted August 29, 2014 I put David Kirk's point saver on my C100 and noticed a positive difference - quicker starting, smoother running. Share this post Link to post Share on other sites
Save Old Iron 1,573 #13 Posted August 29, 2014 Thanks guys, I was led to believe by the salesman that it worked on all points and breaker motors, good to know it only works for magneto engines. Look at the situation from the perspective of the sensor. Its logic is simple. When I see a magnet, I fire the coil. If your HH60 or K series has several magnets on the flywheel, the module is always firing the coil. In the case of the K series tri pole magnets, that would be 18 times in one revolution of the flywheel, 72 times within the 4 cycle sequence of the K engine. Single magnet flywheels, no problem. Even dual magnet flywheels that may fire the coil during the beginning of the intake cycle, no real issue. But 72 times during 4 cycle operation - nope. Share this post Link to post Share on other sites
KC9KAS 4,744 #14 Posted September 20, 2014 (edited) Hummmmm, I might check into this for a 1100 Clinton. The spark is very weak and intermitent Edited September 20, 2014 by KC9KAS Share this post Link to post Share on other sites
Horse46 519 #15 Posted November 5, 2014 I kinda get the whole to many magnets thing, but who can tell me which my engine has? Do I need points saver or electronic ignition? Model # K241AS. Spec # 46766d Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,838 #16 Posted November 5, 2014 Do you have a 1977 B-100 8-speed model 71-10K801? The spec number posted for this model is a bit different - K241S-46756D The spec number is what really identifies the engine. Garry Share this post Link to post Share on other sites
Horse46 519 #17 Posted November 5, 2014 Hi Gary I have a 1978 C-101 Share this post Link to post Share on other sites
Aldon 4,828 #18 Posted November 5, 2014 So if you go to an Automotive type charging system and remove all but one magnet, will it work with electric ignition? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,838 #19 Posted November 5, 2014 Hi Gary I have a 1978 C-101 You have battery ignition. The battery powers the ignition coil which should be mounted on the flywheel cover next to the carburetor. The points are under a small tin cover on the front right side of the engine near the bottom so the point saver will work for you. Garry Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,838 #20 Posted November 5, 2014 So if you go to an Automotive type charging system and remove all but one magnet, will it work with electric ignition? The location of the magnet for electronic ignition determines the ignition timing. Good luck trying to figure that out. Garry Share this post Link to post Share on other sites
Horse46 519 #21 Posted November 5, 2014 You have battery ignition. The battery powers the ignition coil which should be mounted on the flywheel cover next to the carburetor. The points are under a small tin cover on the front right side of the engine near the bottom so the point saver will work for you. Garry Garry you're a gent, thank you. Just a pity as the that point saver costs more than the electronic ingnition. 1 Share this post Link to post Share on other sites
Copper116 63 #22 Posted March 27, 2020 Horse46, did the Point Saver work for your K241 C101 ??? I have one I'm working on and thought if it works, I may try it and not have to fuss with points. Thanks. Share this post Link to post Share on other sites
953 nut 62,967 #23 Posted March 27, 2020 16 minutes ago, Copper116 said: Horse46, did the Point Saver work for your K241 C101 ??? I have one I'm working on and thought if it works, I may try it and not have to fuss with points. Thanks. This post is five years old. you may be better off sending a PM. Share this post Link to post Share on other sites
Horse46 519 #24 Posted March 30, 2020 Yes quite an old post, I had to re read it to see what it was about! No i didn't go down this route and TBH I have never had to re adjust the points either. It always starts and run fine as long as the battery is charged. Share this post Link to post Share on other sites
