saguaro 0 #1 Posted October 5, 2008 I paint stripped the trans today. I have up/down play in the input and break shaft's How hard is it to replace those bearings and what tools whould I need. Will the hole thing pall apart if I slit the case. :banghead: Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted October 5, 2008 Go HERE, enter "L-155" as the model number,select "Riding Mowers/Tractors & Attachments" as the product type, and hit the "submit" button. From there you can download (for free) the Wheel Horse 6 & 8-Speed Mechanical Transmission manual (#492-4004) which also has the 3 speed repair instructions. Share this post Link to post Share on other sites
kpinnc 15,685 #3 Posted October 5, 2008 It's not that hard to work on these trannies, BUT- I would suggest you download the mechanical transmission repair manual. It is about 70 pages covering all of the trannies. It even breaks down the different ones for different tractors by model and year. It really makes your first one much easier... You can download it from Toro.com. Kevin Share this post Link to post Share on other sites
kpinnc 15,685 #4 Posted October 5, 2008 TT beat me to it! Kevin Share this post Link to post Share on other sites
saguaro 0 #5 Posted October 5, 2008 Thanks Guys. I went to toro manuales saw the 6 and 8 trans and thought it was leading me to the wrong manual. Went to toro master list. Are most of the bearins still available? Share this post Link to post Share on other sites
sorekiwi 761 #6 Posted October 5, 2008 Are most of the bearins still available? All the needle roller bearings are common Torringtons available through any bearing house. The 2 ball bearings on the sides of the diff are "specials" that I've never found an alternate source for (Toro want about $50 apiece for them). The gasket is still available from Toro, seals are available generically, I usually get them from NAPA. I made up a set of drivers from aluminum to remove and install the bearings and seals, but you can improvise with various sockets etc. Share this post Link to post Share on other sites
saguaro 0 #7 Posted October 5, 2008 Thanks Mike very helpful. :banghead: Share this post Link to post Share on other sites
