Wishin4a416 2,609 #51 Posted December 1, 2015 Been a long time since I got to work on this Ole girl. To many irons in the fire. Its Kohler time, or is that "Miller Time", but I got the engine tore down and decreased. Has a nice .002" groove in the jug from a broken top ring so its off to the machine shop soon. I will rebuild this in the Man Cave where there is some heat! 10 Share this post Link to post Share on other sites
98layinframe 23 #52 Posted December 10, 2015 Nice work so far, looks like it's turning out great! Are you by chance parting out that 414-8 you pillaged parts off of? Share this post Link to post Share on other sites
SylvanLakeWH 32,022 #53 Posted December 11, 2015 Nice job so far! Very sharp! 2 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,587 #54 Posted December 11, 2015 Ok Jack, moving right along, step at a time. Glenn 1 Share this post Link to post Share on other sites
Wishin4a416 2,609 #55 Posted December 11, 2015 On 12/10/2015 at 3:43 PM, 98layinframe said: Nice work so far, looks like it's turning out great! Are you by chance parting out that 414-8 you pillaged parts off of? Not really. I have been stealing parts off of it for awhile. What are you needing? Share this post Link to post Share on other sites
Wishin4a416 2,609 #56 Posted December 13, 2015 Fresh back from the machine shop with a .010" overbore and new guides and valve job. Time to get busy. 6 Share this post Link to post Share on other sites
98layinframe 23 #57 Posted December 14, 2015 On 12/11/2015 at 4:56 PM, Wishin4a416 said: Not really. I have been stealing parts off of it for awhile. What are you needing? Just thinking the foot pans. I was considering widening the stock ones on mine, and using a second set would be easy. Share this post Link to post Share on other sites
Wishin4a416 2,609 #58 Posted December 15, 2015 9 minutes ago, 98layinframe said: Just thinking the foot pans. I was considering widening the stock ones on mine, and using a second set would be easy. Let me look in the shed this weekend. Its to dark when I get home during the week. I should have some. Share this post Link to post Share on other sites
Wishin4a416 2,609 #59 Posted December 24, 2015 Its a Long Block again. Hope to get it set on the Tractor Saturday and then to start finishing it up. I wouldnt mind seeing this warm weather stick around a little longer so the garage stays warm. 4 Share this post Link to post Share on other sites
Wishin4a416 2,609 #60 Posted January 2, 2016 A little more progress today before having to go away. Maybe I can light er up soon if I get some more garage time. 14 Share this post Link to post Share on other sites
Digger 66 3,530 #61 Posted January 2, 2016 Nice work . 2 Share this post Link to post Share on other sites
WHnoviceRR 4 #62 Posted January 3, 2016 The paint combination brings out so much detail. Excellent job. 2 Share this post Link to post Share on other sites
mikekot3 93 #63 Posted January 3, 2016 Very nice paint work. What did you use for the carburetor? Or is it cleaned up with clear coat? 1 Share this post Link to post Share on other sites
Wishin4a416 2,609 #64 Posted January 3, 2016 2 hours ago, mikekot3 said: Very nice paint work. What did you use for the carburetor? Or is it cleaned up with clear coat? I just used brake cleaner then the SOS pad. Rinse real good in hot water and blow off and then swish around in Acetone. 2 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,587 #65 Posted January 3, 2016 Jack. one word. WOW! Glenn 2 Share this post Link to post Share on other sites
jeff lary 173 #66 Posted January 3, 2016 On 12/13/2015 at 6:16 PM, Wishin4a416 said: Fresh back from the machine shop with a .010" overbore and new guides and valve job. Time to get busy. are you sure that cylinder is not cracked the entire length? I can clearly see a crack on the far side extending down. That is not a ring gouge as a gouge would have created a straight up and down line grove this line I see is a fine crack varying right and left as it goes down the cylinder. I may be wrong but I don't think so. Share this post Link to post Share on other sites
Wishin4a416 2,609 #67 Posted January 3, 2016 No cracks. I checked it out with a light. Gouge is shown in Post 51. Share this post Link to post Share on other sites
jeff lary 173 #68 Posted January 3, 2016 ok then good luck my mistake Share this post Link to post Share on other sites
Thor27 892 #69 Posted June 9, 2016 Beautiful tractor! Are there any finished pictures? 1 Share this post Link to post Share on other sites
