chev0545 236 #1 Posted August 1, 2014 is there any adjustment to smooth the jerking on a 314-hydro forward & backwards Share this post Link to post Share on other sites
Nathanielperz 150 #2 Posted August 6, 2014 My 1276 transmission jerked because the belt was old and stretching which caused it to slip. Share this post Link to post Share on other sites
SousaKerry 503 #3 Posted August 6, 2014 Under the seat there is a friction adjustment that could be set too tight. Also remove the panel between the seat and stearing column and check for debris and broken or worn parts. Also it is a good idea to lubricate all the linkages under the panel. If your motion control lever is near the steering wheel lubricate those joints as well. 1 Share this post Link to post Share on other sites
Kurt-NEPA 755 #4 Posted August 9, 2014 Hey Dave, have you had any luck getting that linkage smoothed out? Share this post Link to post Share on other sites
Navig8r 132 #5 Posted August 9, 2014 mine was on the sticky side too so I took the covers off and lubed up all the linkages just now . we'll see how it is later when I get to take it out for a test drive Sent from my ADR6350 using Tapatalk 2 Share this post Link to post Share on other sites
Dirtdog524 61 #6 Posted January 16, 2015 i realize the posting is old but i would check the plate where the trans bolts to the frame. This area appears like it was under engineered . Share this post Link to post Share on other sites
