nhunt308 143 #1 Posted July 25, 2014 does anyone have the inside dimensions of the slot hitch? (at work about to make an slot to sleeve adapter) forgot to measure my slot hitch. thanks. Share this post Link to post Share on other sites
Geno 1,930 #2 Posted July 25, 2014 (edited) I have one here that is 2.059 wide x .697 high. I have a tongue for it that fits nicely that is 2.001 x .615. I'd like to see a pic of it when you're done if possible. Edited July 25, 2014 by Geno Share this post Link to post Share on other sites
nhunt308 143 #3 Posted July 25, 2014 Awesome thanks! Ill will definitely post some 1 Share this post Link to post Share on other sites
nhunt308 143 #4 Posted July 25, 2014 Here is a couple pics of the progress 2 Share this post Link to post Share on other sites
KC9KAS 4,745 #5 Posted July 25, 2014 Very nice. I made one of these a month or so ago, and I made it too short.....Doesn't stick out far enough for the cable connection on the slot hitch to clear the 5/8" bolt that stabizes the plow. Otherwise mine looks like yours (only shorter)! Share this post Link to post Share on other sites
nhunt308 143 #6 Posted July 25, 2014 I thought about making mine shorter. This is my lifting mechanism. .. Share this post Link to post Share on other sites
nhunt308 143 #7 Posted July 26, 2014 And its done... now I just need some attachments 1 Share this post Link to post Share on other sites
876wheelhorse 46 #8 Posted July 27, 2014 what the total length? Share this post Link to post Share on other sites
KC9KAS 4,745 #9 Posted July 27, 2014 I will tell you that 4" is too short! Share this post Link to post Share on other sites
nhunt308 143 #10 Posted July 27, 2014 Mine is 10" total Share this post Link to post Share on other sites
CasualObserver 3,411 #11 Posted July 28, 2014 I wouldn't go shorter...that's about right. I'm thinking the factory one is 12". I'd have to measure to tell you for sure. I think there's a post with that info somewhere. By the way... you're picture shows it in the hitch upside down. It should be mounted flat side up, with bracing underneath. Share this post Link to post Share on other sites
nhunt308 143 #12 Posted July 28, 2014 Ha. Thanks good to know..box blade will be here in a week. Also dont go by my 10" length if planning one for yourself I just guessed from pictures. Will be using a winch to lift mine so I wasnt to worried about clearance. Share this post Link to post Share on other sites
KC9KAS 4,745 #13 Posted July 29, 2014 By the way... you're picture shows it in the hitch upside down. It should be mounted flat side up, with bracing underneath. Are you sure about this? I thought I have seen them on tractors mounted just like we see in his photo.....Maybe they were wrong too! Share this post Link to post Share on other sites
CasualObserver 3,411 #14 Posted July 29, 2014 Are you sure about this? I thought I have seen them on tractors mounted just like we see in his photo.....Maybe they were wrong too! Yes I'm sure. You probably have. But by the instructions it goes this way. Via Tapatalk 4 Share this post Link to post Share on other sites
KC9KAS 4,745 #15 Posted July 30, 2014 (edited) Yes I'm sure. You probably have. But by the instructions it goes this way. Via Tapatalk 4 Well, in that case, mine isn't too long I mean short! One of the bolts to tighten up the plow was hitting on the cast part where the cable lift is attached. Thanks for setting me straight! Edited July 30, 2014 by KC9KAS Share this post Link to post Share on other sites
CasualObserver 3,411 #16 Posted July 30, 2014 Glad to help.... and yeah. I assume it goes that way to eliminate interference with the sway plate bolts. Via Tapatalk 4 Share this post Link to post Share on other sites
