gary m 4 #1 Posted July 24, 2014 Hello everyone, I am new to this great site, I am 68 and until yesterday my main tractor was a Simplicity. This machine is also a great unit, the problem I have with it is in the winter time when I switch to the plow and have to turn the blade, I have to get off and move said plow. Since I'm getting up their in age and I've had long time back problems, I wanted to get a Wheel horse, the problem is that I had to buy used. I live in Ct., I went to Mass. and bought a used plow for a wheel horse (at this point I didn't own a wheel horse), I paid $175.00, it came with weights and chains, all in excellent shape. I thought about trying to conform this plow to the Simplicity, but that was not going to work. So I found a used Wheel horse with nothing but the tractor (just what I needed), I paid $325.00 for it. Hour meter is 750. I bought a Toro Wheel Horse Classic 310-8speed, Kohler Magnum 10 #'s on plate 311ok801 10589 USA 9242 South Bend Now the Questions, 1. What does it mean 8 speed when there's only a low and high position 2. When brake is in off position the pedal is really far back, is this normal? 3. I will be using this unit only for plowing snow, will this unit do the job? 4. What oil should I use in it. 5. What year is this unit. 6. Where do you get extra keys made 7. I didn't see a oil filter should there be one on it? 1 Share this post Link to post Share on other sites
Geno 1,930 #2 Posted July 24, 2014 (edited) Hey Gary and congrats on your first Horse. In answer to your questions - 1. Reverse is included with the 3 forward speeds making 4, High and low of those make 8 different speeds. 2. Depends, if you can not set the parking brake then someone adjusted it too tight, if you can set the brake it's ok. 3. Absolutely. It will run a snow blower well also. 4. I've used Mobile 10W-30 in mine for 27 years but peoples opinions differ on oils. 5. We need the model number from under the left side of the seat on the fender panel to find out. 6. Lowes or any mower shop, they are generic and don't need to be cut. 7. I've not seen a filter on a 310-8 before. Edited July 24, 2014 by Geno Share this post Link to post Share on other sites
Foozerush 40 #3 Posted July 24, 2014 Welcome to RS! Your 310-8 should do just fine plowing snow. I just got a 310-8 this spring for the rental, so I'm getting to know mine little by little. When you got your plow, did you get the rear axel bracket? Need that to attach plow to tractor. Chains and weights will help traction for pushing that fluff. Here are some pics of mine, and with my 416-8. Here is a pic of rear axel bracket on my 416-8, it will be the same. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,499 #4 Posted July 24, 2014 Gary. Welcome to the best sight around. You will have 2 wheel horses soon I bet. Don't forget pictures. Glenn Share this post Link to post Share on other sites
KC9KAS 4,745 #5 Posted July 24, 2014 I can't add anything else to the above posts other than you will be impressed with the abilities of your Wheel Horse! Share this post Link to post Share on other sites
Racinbob 12,478 #6 Posted July 24, 2014 Sounds like you got ya a good one. Share this post Link to post Share on other sites
rmaynard 16,758 #7 Posted July 25, 2014 31-10K801 is the correct way to read the ID number on your 1990 310-8 Garden Tractor. Share this post Link to post Share on other sites
Molon_Labe 731 #8 Posted July 25, 2014 Nice horse and welcome!!! Share this post Link to post Share on other sites
gary m 4 #9 Posted July 25, 2014 Thanks for all the nice comments and I do feel more than welcome. When I bought the Wheel Horse I made a deal with the owner that he would install the plow and weights and chains, which he did. I will take some pics tomorrow and post them tomorrow, it needs cleaning, that I can do! Again I really do appreciate the help, if anyone has the leather cover, for that seat, or a cover, for sale let me know, mines needs help, the frame and foam are ok. Thanks Gary Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,881 #10 Posted July 25, 2014 The brake pedal should come back to the footrest but over time it gets bent down so the pedal misses it. An adjustable wrench works well to bend the metal back into shape. Garry Share this post Link to post Share on other sites
jackhammer 550 #11 Posted July 25, 2014 Good for you and your first WheelHorse . Welcome to RedSquare. You will be looking for a deck next. Share this post Link to post Share on other sites
papaglide 542 #12 Posted July 25, 2014 Welcome to Red Square!! And congrats on your first Wheel Horse. Once you get used to this tractor, you will love the simplicity of it. So much so you may want more than one.... Share this post Link to post Share on other sites
gary m 4 #13 Posted July 25, 2014 Well I tried to put the pics on this page, but I can't do it, their in the gallery under just uploaded,(under gary morton's 310-10) if you want to see them, sorry. Gary Share this post Link to post Share on other sites
