slammer302 2,156 #1 Posted July 22, 2014 I have a lawn ranger 33r and I'm wondering how well a Kohler k181 will fit under the hood its pretty tight with the h60 on there now I know its been done before but I'm curious if there is any changes that will need done? Share this post Link to post Share on other sites
CasualObserver 3,411 #2 Posted July 22, 2014 If I remember correctly, you just eliminate the engine riser plate, bolt the K-181 directly to the frame, and make a minor hole adjustment to the belt guard for the slightly different mounting point on the engine. Share this post Link to post Share on other sites
Terry M-(Moderator) 2,266 #4 Posted July 22, 2014 (edited) I plan doing a k181 or similar conversion on one of my Lawn Rangers someday. Also, '62 thru '64 lawn rangers have a fuel tank independent from the engine which make this engine conversion even less complicated ... Look forward to seeing your conversion Edited July 23, 2014 by Terry M Share this post Link to post Share on other sites
slammer302 2,156 #5 Posted July 22, 2014 My lawn ranger has the 2 peice alum gas tank Share this post Link to post Share on other sites
slammer302 2,156 #6 Posted July 22, 2014 And the gas tank has been nothing but trouble for me it had a crack in it when I got it I used some sealer called red kote very expensive but has worked for about a year and now its stated to seep a little around the gasket area Share this post Link to post Share on other sites
Terry M-(Moderator) 2,266 #7 Posted July 22, 2014 sorry...I see yours is a 63 model and I can understand your frustration....my 64 ranger has a one piece (soldered together ) gas tank under the hood....works nice. I've seen tanks like yours welded up before...don't know if thats a possible option for you or not..?? Share this post Link to post Share on other sites
slammer302 2,156 #8 Posted July 23, 2014 I tried to weld the crack but it didn't work all that well I think it is cast alum Share this post Link to post Share on other sites
sorekiwi 761 #9 Posted July 23, 2014 My Ranger has a K181 in it, easy swap, just lose the riser plate and it will bolt straight to the frame, the holes will line right up. There are a bunch of threads on here giving advice on sealing up the two piece tanks. 1 Share this post Link to post Share on other sites
slammer302 2,156 #10 Posted July 23, 2014 Thanks for all the info Share this post Link to post Share on other sites
