tom h.hill 10 #1 Posted July 16, 2014 I found the original rear wheels for my 1054.so I go to bolt the wheels on.the lug it pattern Is right but there ain't no threads in the lug holes. Who ever had this Wheelhorse Before me made a spacer plate drilled An tapped new holes in spacer plate an the hub. Had some kind of car rim bolted up.they didn't have the correct rims Evidently. So tell me do the original rims get nut and bolted to the hub. Like I said no threads for lug bolt Share this post Link to post Share on other sites
groundhog47 447 #2 Posted July 16, 2014 (edited) You might try the car type studs with the splines on hub side and press them in. If a local car junk yard is near that would be your cheapest way to experiment. Or go by local auro parts and secure 1 or two different styles. Changing hubs pretty costly, but the bolts/nuts combo would work, a bit three handed operation to get started I would sumize. If you could also submit a photo we could be a bit more certain of what you have lefr ro work with. Edited July 16, 2014 by groundhog47 Share this post Link to post Share on other sites
tom h.hill 10 #3 Posted July 16, 2014 I didn't even think that there might of been studs in there. And when they made up the spacer plate to put the wheels on they most likely knocked out the studs that where there in the first place. Good thinking thanks. And when it comes to the pics I'm still trying to figure out how to get them from one place to the other I didn't even think that there might of been studs in there. And when they made up the spacer plate to put the wheels on they most likely knocked out the studs that where there in the first place. Good thinking thanks. And when it comes t o the pics I'm still trying to figure out how to get them from one place to the other Share this post Link to post Share on other sites
tom h.hill 10 #4 Posted July 16, 2014 I'll work on getting pics of both of my wheel horses. Share this post Link to post Share on other sites
SALTYWRIGHT 861 #5 Posted July 16, 2014 the 1054 w/h has 9/16 lugs not 1/2 inch. are you trying to use 1/2 ? Share this post Link to post Share on other sites
tom h.hill 10 #6 Posted July 16, 2014 I'm not using anything yet. But I am going to find the right lugs to press in. The wheels were bolted on. It was a butcher job. Wheels an tires looked like they came off of a Mazda. Share this post Link to post Share on other sites
Tankman 3,528 #7 Posted July 17, 2014 Didn't know 'bout 9-16 x 20 lug bolts on WH's. But, would work the same as I noted earlier. Take a peek-a-boo at my earlier reply here: Share this post Link to post Share on other sites
tom h.hill 10 #8 Posted July 17, 2014 I got both sets 1/2 and 9/16. The 1/2 is what I used. The nearled end on the 9/16 was to big to fit in hole. Thanks for the help. An I'm still working on the pics. I got both sets 1/2 and 9/16. The 1/2 is what I used. The nearled end on the 9/16 was to big to fit in hole. Thanks for the help. An I'm still working on the pics. I got both sets 1/2 and 9/16. The 1/2 is what I used. The nearled end on the 9/16 was to big to fit in hole. Thanks for the help. An I'm still working on the pics. I got both sets 1/2 and 9/16. The 1/2 is what I used. The nearled end on the 9/16 was to big to fit in hole. Thanks for the help. An I'm still working on the pics. Share this post Link to post Share on other sites
