aaubrey96 0 #1 Posted July 15, 2014 This is the most "stock" picture I have. It is old enough to have the angle iron frame and it has a 14hp kolher engine Share this post Link to post Share on other sites
WH nut 553 #2 Posted July 15, 2014 Late 80s from what I can tell Share this post Link to post Share on other sites
Geno 1,930 #3 Posted July 16, 2014 Can you post the model and serial numbers? They are under the seat on the left side (sitting on tractor). I have one of those myself, great tractor. Mine is an 87 and looks like that one, it does not have the Toro on it either. There are several people here that can tell you the exact year from those numbers. Share this post Link to post Share on other sites
can whlvr 994 #4 Posted July 16, 2014 the 414 was made only in 1986,87,88,89 the 86 had a k series engine and all the newer had the m series,there wasn't much difference between the years,but if you can find the serial number,(between your legs on the fender pan)it would be a help Share this post Link to post Share on other sites
aaubrey96 0 #5 Posted July 16, 2014 The serial numbers under the seat are not readable the tag was there but the numbers were not. It is a kohler magnum so would that be k or m? Share this post Link to post Share on other sites
oldredrider 2,553 #6 Posted July 16, 2014 "M"=Magnum Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,765 #7 Posted July 16, 2014 If the engine numbers are M14S-601524 it is a 1987 model. If the numbers are M14S-601540 it is a 1988 or 1989. The engine serial number may narrow it down. Garry Share this post Link to post Share on other sites
aaubrey96 0 #8 Posted July 17, 2014 ok so its a 87 then. thanks for the help Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,765 #9 Posted July 17, 2014 ok so its a 87 then. thanks for the help Your tractor's model number is 31-14K802 Garry Share this post Link to post Share on other sites
Wheel-N-It 2,976 #10 Posted July 18, 2014 Thank you Garry. I may be able to narrow down the year model of my 414-8. Its a Magnum powered tractor, and now I can check the numbers on the engine. The numbers on the seat pan are long gone. Share this post Link to post Share on other sites
zieg72 209 #11 Posted July 19, 2014 If the engine numbers are M14S-601524 it is a 1987 model. If the numbers are M14S-601540 it is a 1988 or 1989. The engine serial number may narrow it down. Garry Not my thread but answered the mystery of my 414-8, THANKS SO MUCH Share this post Link to post Share on other sites
