Woodsie 51 #1 Posted July 15, 2014 1991'ish 520H, adjusted neutral, now when brake pedal is pushed in far enough to lock E-Brake, makes the tractor leave neutral and start to move forward. How do i adjust the brake pedal to move linkage to neutral?? Share this post Link to post Share on other sites
WH nut 553 #2 Posted July 15, 2014 Hold the lever in neutral with park brake applied adjust your traction control cam to neutral. Share this post Link to post Share on other sites
Woodsie 51 #3 Posted July 15, 2014 if i push the brake pedal in the whole way. it moves the hand lever out of neutral. so do i have to readjust that eccentric? hate to lose speed or reverse. Share this post Link to post Share on other sites
WH nut 553 #4 Posted July 15, 2014 you can try adjusting the brake band Share this post Link to post Share on other sites
Woodsie 51 #5 Posted July 15, 2014 No its tight. when i lock e brake. the hydro is straining to move forward, cause the pedal has moved it out of neutral. Share this post Link to post Share on other sites
Ed Kennell 45,247 #6 Posted July 15, 2014 You may need to lengthen the connecting rod between the yoke and the cam plate if you are out of adjustment on the eccentric. 1 Share this post Link to post Share on other sites
