genehorse 1 #1 Posted July 13, 2014 My C-160 Automatic has the fixed drawbar. However, up above it there is a shaft with a cable attached that goes up front beneath the tractor and is not connected to anything. It does have a post and key pull at the front end of the cable. What is this supposed to be connected to? Share this post Link to post Share on other sites
WH nut 553 #2 Posted July 13, 2014 That's the lift cable for a tiller, plow, disc harrow or many other ground equipment Share this post Link to post Share on other sites
squonk 47,423 #3 Posted July 13, 2014 It attaches to your lift rock shaft. My 76 didn't come with a cable so I had to custom build one. You need a slot or clevis hitch for the rear. Share this post Link to post Share on other sites
