Nathanielperz 150 #1 Posted July 12, 2014 Hey everyone my grandfather has a Wheel Horse... im not sure the model or the engine model I know the engine is a kohler... Anyway we cant get the thing to stay running... it starts up okay but once it worms up it stalls and wont start up again... Here is what we HAVE done... Changed the fuel filter Cleaned the Carb Checked the gas for water Here is what we HAVE NOT done... changed spark plug cleaned fuel pump Please let me know what this could be... Thanks in advance, Nate Share this post Link to post Share on other sites
AMC RULES 37,220 #2 Posted July 12, 2014 Condenser maybe? Find out what engine it is Nate? Share this post Link to post Share on other sites
Nathanielperz 150 #3 Posted July 12, 2014 I think he has a 520 H if that helps any... I don't know what kind of engine it has kohler or briggs that's all I know with out going there... Thanks Nate Share this post Link to post Share on other sites
nylyon-(Admin) 8,118 #4 Posted July 12, 2014 A 520 would be an Onan, in which case could be the ignition module. Need to get the exact model and engine. Share this post Link to post Share on other sites
Nathanielperz 150 #5 Posted July 12, 2014 Ok I will talk to my grandfather and get back to you guys Thanks Nate Share this post Link to post Share on other sites
Nathanielperz 150 #6 Posted July 13, 2014 The engine is definitely a Kohler I asked my grandfather.... he doesn't know the model of the tractor though... Does this help at all? Thanks, Nate Share this post Link to post Share on other sites
motox25 36 #7 Posted July 14, 2014 If it were me, I'd hook up an in line spark tester between the line and plug and see if it's losing spark when it dies. If it does it's likely the coil. Could also be the fuel cap vent, you could loosen the gas gap and run it for awhile to see if it continues to stall. If it no longer stalls, replace the gas cap. Share this post Link to post Share on other sites
Steve Warner 1 #8 Posted July 14, 2014 I had a problem with a Kohler like that and it was the condenser. Just a thought and they are easy to change on those old engines Sent from my iPad using Tapatalk Steve Lincoln IdealArc 250 Lincoln SA200 1966 Redface 1 Share this post Link to post Share on other sites
Terry M-(Moderator) 2,255 #9 Posted July 14, 2014 Sounds like there is some confusion as to what this tractor is. Like stated above,find out what you have..then it will be easier for the many helpful and friendly members here on RS to help you diagnose your engine issues .....maybe posting some pics of the tractor could help ?? Share this post Link to post Share on other sites
Nathanielperz 150 #10 Posted July 14, 2014 The tractor is a 416-8 Share this post Link to post Share on other sites
boovuc 1,090 #11 Posted July 15, 2014 The 416-8 Speed came in three flavors over the years. A Kohler 16 horse single cylinder K341, a single cyl M16 Kohler Magnum and the later Onan 16 horsepower twin. Please look at the engine and tell us if it's a single cyl or a twin and that will remove any doubt we have about any advice we can give Nate. If he is sure it's a Kohler, we need to know if it's the older K series with a breaker ignition or the Magnum series with a breakerless, (no points or condenser), ignition. It could be a couple things causing it but very different things between those three motors. Share this post Link to post Share on other sites
WH nut 553 #12 Posted July 15, 2014 A picture would tell the whole story Share this post Link to post Share on other sites
Nathanielperz 150 #13 Posted July 15, 2014 (edited) I can try to get some pictures of it... i will let you guys know... Thanks, Nate Sorry i didnt mean to quote anything... Edited July 15, 2014 by Nathanielperz Share this post Link to post Share on other sites
boovuc 1,090 #14 Posted July 16, 2014 It's OK Nate. To my knowledge, I have never uttered anything that anyone would want to quote! 3 Share this post Link to post Share on other sites
Nathanielperz 150 #16 Posted July 18, 2014 Im going to get pictures of the tractor today Share this post Link to post Share on other sites
Nathanielperz 150 #17 Posted July 18, 2014 Here are the pics.... 1 Share this post Link to post Share on other sites
Nathanielperz 150 #18 Posted July 19, 2014 What do you think the problem is? Any ideas are greatly appreciated! Thanks, Nate Share this post Link to post Share on other sites
chazm 413 #19 Posted July 20, 2014 Well Nate,from your pics ,I can tell ya what the problem is.. You need to put a battery in it .... You said you replaced the fuel filter... did you replace the gas line ??? From the looks of your its been sitting awhile & old gas line deteriorates after time. Also clean the tank to get any junk out of it as well ... This would be a starting point buddy.... 1 Share this post Link to post Share on other sites
pacer 3,177 #20 Posted July 20, 2014 (edited) Two things I would try that will help considerably in elimination of the 2 main possible areas (and easy to do) When it dies, quickly remove the spark plug, reconnect the wire and lay the plug on the head, spin the engine over with the starter and see if the plug is sparking - if it does re-instal the plug, if not then we can look into that. Doing this first and quickly will help if its a heat related problem - ie coil/condenser getting hot. Then, with the air filter removed squirt some fuel into the carb throat (brake cleaner, WD 40, start fuel, etc) if it fires up then of course its a fuel related problem. One or the other should point to ignition or fuel problems, then we can further diagnose the problem -- good luck. Edited July 20, 2014 by pacer Share this post Link to post Share on other sites
Nathanielperz 150 #21 Posted July 21, 2014 Two things I would try that will help considerably in elimination of the 2 main possible areas (and easy to do) When it dies, quickly remove the spark plug, reconnect the wire and lay the plug on the head, spin the engine over with the starter and see if the plug is sparking - if it does re-instal the plug, if not then we can look into that. Doing this first and quickly will help if its a heat related problem - ie coil/condenser getting hot. Then, with the air filter removed squirt some fuel into the carb throat (brake cleaner, WD 40, start fuel, etc) if it fires up then of course its a fuel related problem. One or the other should point to ignition or fuel problems, then we can further diagnose the problem -- good luck. We cleaned the gas tank.... I will look at the gas lines. Actually the batter might be the problem.... No wonder it wouldn't crank over... Share this post Link to post Share on other sites
