kudzu3 323 #1 Posted July 12, 2014 I'm getting close to completing my B 80 restoration and have a question about grounding. I wish I knew more about this electrical stuff, but just don't. I know that there has to be ground points but don't know where (or how). Does grounding simply mean that where required, I just need metal to metal? Can someone kinda explain for me please, in a brief simple way that I can understand? Thanks Share this post Link to post Share on other sites
chazm 413 #2 Posted July 12, 2014 (edited) The neg cable goes from the batt to usually a bolt on the eng. & or frame - Hope this helps ..Keep us posted Edited July 12, 2014 by chazm Share this post Link to post Share on other sites
rmaynard 16,215 #3 Posted July 12, 2014 In a 12 volt DC circuit, you must have (+) positive, and (-) negative. From the (+) terminal of the battery, a wire goes to the (+) terminal of any item that requires 12 volts to operate. Some of those item are connected to switches, others to relay, still others to solenoids. For example, the starter is the biggest user of 12 volts on the tractor. The (+) wire from the battery goes to the starter through the solenoid, and in order to complete the circuit, the (-) terminal of the starter, which happens to be the case, connects to the engine block, which is connected to the frame, which is connected to the (-) terminal of the battery. So think of everything that is metal, that is connected to anything else that is metal, i.e. engine to frame, frame to dash tower, dash tower to dash plate, dash plate to ignition switch, etc. all becomes part of the ground system by virtue of the fact that the engine and frame and anything else that is connected to them are connected directly to the (-) negative terminal of the battery. 4 Share this post Link to post Share on other sites
kudzu3 323 #4 Posted July 12, 2014 Thanks! Very good explanation Bob, I believe my simple mind understands. Can the bolts connecting the item suffice as the ground connection, or do I need to remove some paint from the surfaces of the items where they make contact? My thinking (after your explanation) is that the bolts, or connectors will work. Again, thanks for the info, I really appreciate it. Share this post Link to post Share on other sites
rmaynard 16,215 #5 Posted July 12, 2014 The bolts generally provide a good ground. If in doubt, use a little sandpaper on the hidden side of the fastener to make sure that you have good contact to the metal. 1 Share this post Link to post Share on other sites
Martin 2,133 #6 Posted July 12, 2014 Very good explanation there, Bob! sometimes a toothed washer or spring washer is all you need to break through the paint. I always use some on the engine mounting point and frame, hood stand etc. doesn't need to be all of them , just one good point of contact and only needed on the parts of the tractor where you need to have an electrical connection. all the part is doing is taking the place of an electrical (-) wire....... you could just do one fastener of every part with a washer or paint removal. take the engine for example, you usually have four bolts and most of the 90s tractors have nylok nuts on the bolts with no spring washer. i put a washer on one of then and that is then the ground path. Share this post Link to post Share on other sites
