stevebo-(Moderator) 8,604 #1 Posted July 10, 2014 Has anyone run a 2 stage 44 inch Toro/Wheel Horse snowblower on a C195? If so, could you tell me if there were any modifications and post a few pics. Thanks in advance! Share this post Link to post Share on other sites
Operator 7 #2 Posted July 13, 2014 I'M IN THE PROCESS RIGHT NOW OF DOING THE SAME THING. THE "MID-A-TACHAMATIC' IS BACK A FEW INCHES SO I HAD TO CUT BLOWER FRAME TO EXTEND IT. PLUS THE LIFT SHAFT WILL NEED TO BE EXTENDED ALSO. I'M NOT HOLLERIN BUT MY "SHIFT" WAS LOCKED AND DIDNT WANT TO RETYPE, sorry...... Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #3 Posted July 13, 2014 Randy-I would like to see some pics of that mod. Share this post Link to post Share on other sites
wallfish 19,373 #4 Posted July 13, 2014 I'm not too familiar with the exact measurements of the C195 but would it be better to move the mid tach a matic forward with a few holes drilled into the frame vs cutting and welding the blower frame? Or, if there's enough room, just add another mid mount location for the blower. That way the blower isn't married to that machine and can still be swapped easily to another one or sold without the tractor. $0.02 Share this post Link to post Share on other sites
fireman 1,022 #5 Posted July 13, 2014 That's what I would do John. Get an extra mid attach a matic which I'm sure Steve has and mount it where it needs to be. I'd also make an extension for the lift rod instead of lengthening it. This way the blower stays stock and could be used on other machines. Steve I can help you make the modifications! Share this post Link to post Share on other sites
Operator 7 #6 Posted July 13, 2014 OK Guys here is the thing, I couldnt add another Mid Tach to the front of origional, not enough room. I have three of the two stage blowers and never, I said never plan on selling my C-195 [i got it from Rick V.]. I thought the thing out even adding on behind blower frame an extension kind of thing. What I did was cut blower frame right behind tension spring base and am getting some flat stock iron to fit inside of those two cut pieces, then I can slide it out for C-195 or if needed slide it back in to origional spot for my 520"s. Extending the push or lift rod isnt to bad of a deal. Once I get the right size flat stock I'll get a picture Steve. I'm running over the road and my free time is one day a week at home, time is limited. I also put the reduction steering from a 520 into the C-195 to help with the extra front weight. Share this post Link to post Share on other sites
Operator 7 #7 Posted July 13, 2014 And you can't move the mid-tach because it holds the pto hoop. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #8 Posted July 13, 2014 Thanks randy. Share this post Link to post Share on other sites
Ken B 3,202 #9 Posted July 18, 2014 Snow blower on a C-195 Steve? Looks like someone is lookin to free up a 520... Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #10 Posted July 18, 2014 I may be looking to unload one.... Share this post Link to post Share on other sites
