pondtet1
no spark in my rj-35
pondtet1
i cleaned the coil, magneto, and points and still nothing. anybody know where i can find parts for it?   thanks!
oldredrider
If that's a Clinton engine, pm member "clinton nut". He's the man.
pondtet1
its a briggs.   model- 5s     type- 700026     serial- 76712.
C-101plowerpower
welcome to rs, are the magnets in the flywheel plenty strong? can't remember those engine's having a seperate coil, are the point's just cleanend? or did you adjust em to the proper settings.
Koen
pondtet1
the magnets in the flywheel are very strong. the coil has a wire that goes down to the condensor or something. and i only cleaned the points. didnt wanna go messing with them without knowing the specs.
pondtet1
sweet thanks. were these the original motor for these tractors?
C-101plowerpower
i don't believe they were, i think original engine would be a clinton, not sure tho. experts will chime in i think
Koen
stevebo
I have 4 of these 35's and know a little about them. From my understanding in 57 you could have one with a kohler k90, clinton 1200 and I believe they offered a briggs but now sure what model.
AMC RULES
Straight from the Horses Mouth lists '55-'56 RJ-25's as having B&S model 8's rated at 2.5 hp.
VinsRJ
Briggs models were only offered in 55 and 56... which was a Briggs Model 8 as Craig has stated.
Steve is on point with the engines offered in 57... you may also even see a Clinton A1200 on a 57 RJ35
