wheelhorse66 10 #1 Posted July 1, 2014 Can't get k301 to charge the battery,what could be the problem? I put a test light on the wire coming off the engine,its working what else could it be? Share this post Link to post Share on other sites
Trouty56 567 #2 Posted July 2, 2014 lots of things.....explain a bit more,,,, Share this post Link to post Share on other sites
rmaynard 16,690 #3 Posted July 2, 2014 (edited) What is the spec number on the K301? And what model/year tractor is it on? Edited July 2, 2014 by rmaynard Share this post Link to post Share on other sites
WH nut 553 #4 Posted July 2, 2014 Could be motor isn't running??? 1 Share this post Link to post Share on other sites
wheelhorse66 10 #5 Posted July 2, 2014 The motor runs good ,but I put it on a 60s model long hood tractor,don't know which one its on a old 3 speed. Share this post Link to post Share on other sites
meadowfield 2,931 #6 Posted July 2, 2014 (edited) more than likely a poor connection: is the R/R unit bolted to a ground ground point? is the connector clean and not melted (they are a weak point)? is the ammeter in circuit? is it faulty? ideally you need a DVM to test and measure, rather than type it all here - look up one of chucks (SOI) master classes on regulator and charging. Edited July 2, 2014 by meadowfield Share this post Link to post Share on other sites
