Kesboy 0 #1 Posted June 30, 2014 Hi, can anyone help me please. I need the threaded exhaust nipple for a K181. I have tried to order one but they are no longer available. Thank you Share this post Link to post Share on other sites
rmaynard 16,886 #2 Posted June 30, 2014 They are just a 1" steel pipe nipple. Any Home Depot, Lowe's or plumbing supply house should have one. Share this post Link to post Share on other sites
SPINJIM 1,996 #3 Posted June 30, 2014 The 1" steel pipe might be hard to find in England because everything is metric. Phone around to find a plumbing supplier who stocks American fittings. Good luck. Jim Share this post Link to post Share on other sites
specialwheelhorse 174 #4 Posted June 30, 2014 Maynard is right on the money, and if that nipple has anger rolled into the inside , grind or get ride of that any easy way you can And forever more do not use a 1 inch 90 degree fitting like so many do. You will loose nearly 5 percent of your power inso doing. Use a nice gentle sweep if need a 90. Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,528 #5 Posted June 30, 2014 Maynard is right on the money, and if that nipple has anger rolled into the inside , grind or get ride of that any easy way you can And forever more do not use a 1 inch 90 degree fitting like so many do. You will loose nearly 5 percent of your power inso doing. Use a nice gentle sweep if need a 90. Right. A 45° will work. That's what's on mine now. Glenn Share this post Link to post Share on other sites
rmaynard 16,886 #6 Posted June 30, 2014 Sorry, I didn't notice that you were in the UK. I could have sent a few home with Neil. Share this post Link to post Share on other sites
