bulldog323 0 #1 Posted June 28, 2014 Hi I have a Wheel Horse 210-h with aBriggs and Stratton, recently the battery stopped charging, I have taken my VOM and checked the charging system and I am getting 27 VAC up to where the diode is but nothing is showing charging when I check the battery to see if a charge is going into it and the charge meter is not showing charging either. I did disconnect the diode which is on spade connector and checked the diode and it shows 535 on the meter but I am not familiar if that is correct reading or not. Any help would be great. Brian Share this post Link to post Share on other sites
squonk 44,036 #2 Posted June 28, 2014 Reverse your VOM leads and see if you get an infinite reading. Also check your fuses. I had a diode go bad on the 210 that I had and it blew the fuse and the PTO stopped working. Share this post Link to post Share on other sites
bulldog323 0 #3 Posted June 28, 2014 I have switched the leads and it doesn't show anything, I have checked the fuse and it was good. Everything works except the charging. Thanks, Brian Share this post Link to post Share on other sites
