By
RedPaul
						I need some wiring help.  I am swapping a Kohler CV16S from a Scotts (JD) in to a Crapsman YT 3000 that formerly had  A Briggs engine. PO of Crapsman forgot the part about checking oil regularly. PO of Scotts changed engine oil but didn't own a grease gun thuse entire front steering gear trashed.
	Before you start throwing things at the screen, the resulting franken tractor (Scottsman CraftDeere?) is being donated for use in maintenance of a city park in the Mexican Town area of Detroit.
	The company I work for donates time, people, and a storage area for park maintenance tools and equipment. Owner is Hispanic and doe gobs of stuff for the community both personally and through our company.
	On to the question.
	I need to marry up the Kohler engine wiring with the Craftsman chassis wiring.
	The Craftsman chassis has the following wires coming to the molex connector that used to connect to the Briggs engine.
	Chassis Blue - Connected to Grey from the  Briggs
	Chassis Blue jumperd to second hole connector - Connected to Red From the Briggs
	Chassis Black and Black with white stripe - both to same connector hole - Connected to Black from the Briggs
	Chassis Orange - Connected to Orange from the briggs
	Chassis White - this wire did not connect to anything on the briggs
	Kohler engine has the following wires coming from the engine going to Molex connector
	2 Red - both go to same connection point
	Yellow
	Black
	White
	Can anyone tell me which Kohler engine wire goes to which Craftsman Chassis wire?
	Free Scotts Chassis with hydro (it would be a roller if the front axles weren't trashed) to whom ever can sort this out.
	Thanks,
	Paul
