fourwheels0 191 #1 Posted June 27, 2014 i have what i believe is a 753 with gear reduction trans. is this a factory thing and can i change it to a regular trans?. serial number is 62-2093 and it has a 7 hp kohler starter generator setup. 1 Share this post Link to post Share on other sites
fourwheels0 191 #3 Posted June 27, 2014 (edited) here it is Edited June 27, 2014 by fourwheels0 2 Share this post Link to post Share on other sites
Racinbob 12,798 #4 Posted June 28, 2014 I don't think your transmission is any different. They made a reduction setup back then that was an add on. It's a bit hard to tell but I believe that's what you have. Removing the reduction unit is a piece of cake. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,012 #5 Posted June 28, 2014 SR-64 speed reducer Garry 1 Share this post Link to post Share on other sites
fourwheels0 191 #6 Posted June 28, 2014 (edited) well i guess i'll pull the belt guard and check it out. thanks guys. after a quick search it looks like the speed reducer was required if you were going to use a 24 inch tiller. Edited June 28, 2014 by fourwheels0 1 Share this post Link to post Share on other sites
fourwheels0 191 #7 Posted July 3, 2014 ok what is the stock size rear pulley and stock belt size on a 753. i put on a 4 inch pulley and 70 inch belt and the belt is too long. i want it back to stock. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,012 #8 Posted July 3, 2014 The original # 1611 pulley is 4" OD and the drive belt is 1/2" x 70" for the 753. The engine drive pulley # 1621 is 2-1/2" OD. The 1623 idler pulley is 3-1/16" OD. Garry Share this post Link to post Share on other sites
fourwheels0 191 #9 Posted July 3, 2014 well somethings not right. rear pulley is 4 inch. belt is 69 3/4 inch idler is stock. front pulley is the stock 2 1/2 inch double pulley. i got it to work but had to use part of the gear reduction unit to take up the extra slack in the belt. i can't upload the pic to photo bucket.i don't know why it won't upload from my phone. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,012 #10 Posted July 11, 2015 i have what i believe is a 753 with gear reduction trans. is this a factory thing and can i change it to a regular trans?. serial number is 62-2093 and it has a 7 hp kohler starter generator setup. Is it possible the 62-2093 serial number is missing some digits? Most are like 62-22113 in 1963.Garry Share this post Link to post Share on other sites
