Zeek 2,298 #1 Posted June 24, 2014 (edited) I just picked up a 1276 at the show. In doing a little examination tonight, I noted that the seat pan does not fit correctly around the belt cover (seems a little too wide) and the hole for the hydro fan seems too small to do any kind of legitimate cooling, which is a bad thing long term. Other that the pitting, I'm sure I can make it work. Does anyone have a photo (and some measurements) of what the original looks like? I could be wrong but I don't think this is it . . . Cecil wouldn't have approved this. Edited June 24, 2014 by Zeek Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted June 24, 2014 Thats a later guard adapted to your tractor, There was a thread a few years ago about measurements for a 1276 guard, a search should find it. Here are some pics of mine: This one isnt mine, but the photo shows the fan arrangement 2 Share this post Link to post Share on other sites
Zeek 2,298 #3 Posted June 24, 2014 Well THAT makes more sense. I was thinking what's the point of a freaking fan when you cover the pump with sheet metal. I kinda hoped I'd get some good responses like yours, thanks. I'd appreciate anymore pics of what works if you wanna share and we'll get fixed up properly. Share this post Link to post Share on other sites
Martin 2,133 #4 Posted June 24, 2014 (edited) heres the thread i think Mike was talking about? now that i look at it again, the 1277 is different from the 1276, belt clutch release is in a different spot. Edited June 24, 2014 by Martin Share this post Link to post Share on other sites
squonk 44,684 #5 Posted June 24, 2014 Zeek, check that filter brand. If it's a Wix or Napa a 1307 isn't correct. Should be a 1410 Share this post Link to post Share on other sites
Zeek 2,298 #6 Posted June 24, 2014 heres the thread i think Mike was talking about? now that i look at it again, the 1277 is different from the 1276, belt clutch release is in a different spot. Thanks, I'll check that out! Zeek, check that filter brand. If it's a Wix or Napa a 1307 isn't correct. Should be a 1410 Thanks Mike, I'll check that because I'm sure that could screw it up. Share this post Link to post Share on other sites
sorekiwi 761 #7 Posted June 25, 2014 My 1276 is in a million pieces right now, any more measurements or photo's you need, just yell. Share this post Link to post Share on other sites
sorekiwi 761 #8 Posted June 25, 2014 now that i look at it again, the 1277 is different from the 1276, belt clutch release is in a different spot. Yes Martin the 1276 is different in this area than the 1277, I think the 1277 system is simpler with less moving parts, I dont have a good picture of the 1276 setup. Share this post Link to post Share on other sites
Martin 2,133 #9 Posted June 25, 2014 the 1276 looks like its almost the same as the 1965 (875, 1075) wheel a matic belt clutch. Share this post Link to post Share on other sites
