Akestner 36 #1 Posted June 23, 2014 ok I was wondering if anyone could explain what parts I need to be able to hookup a single bottom plow and discs for the back of my tractor. Share this post Link to post Share on other sites
Kegler 68 #2 Posted June 26, 2014 Since no one else has jumped in I guess I will, but it depends on the type of connedtor the plow has on it. The most common is a "brinley hitch" type that takes a special hitch mounted to the tractor to attatch. Most disk'a just use a standard fixed hitch, or a slot hitch if it has a streight bar with a hole in it for atachment. With a slot hitch it can be raised. Does the tractor hav any kind of hitch attached to the rear at all. Most hitches can be found on ebay or in the classifieds on here. The streight and slot hitches are not too expensive but the "brinley's" can be a little salty. Share this post Link to post Share on other sites
Akestner 36 #3 Posted June 26, 2014 I have I guess what is the slot hitch I don't actually have a plow but I want to get everything I need before I buy one I also need the rockshaft and the cables and cable tube Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Tankman 3,526 #4 Posted June 26, 2014 Take a peek-a-boo at Parts Tree: http://www.partstree.com/parts/?lc=Toro+Consumer&mn=41-20O801 Share this post Link to post Share on other sites
Akestner 36 #5 Posted June 26, 2014 Thanks for the info I see there's a couple things that are discontinued Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
leeave96 495 #6 Posted June 26, 2014 Have a look see at the manuals section and find clevis hitch. That's all you need! Good luck, Bill Share this post Link to post Share on other sites
