Sodaking27 1,108 #1 Posted June 23, 2014 Bronco 14 not charging. Does anyone have a wiring diagram. I looked through the site and only saw the one for the 72 Bronco which is not the same as the 71. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,986 #2 Posted June 23, 2014 What is different between 1971 and 1972? They both use the 5-terminal 4-position #8362 ignition switch for breakerless ignition and 15 amp charging stator. Garry Share this post Link to post Share on other sites
Sodaking27 1,108 #3 Posted June 23, 2014 Garry There is no standard coil or solenoid on the 71. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,986 #4 Posted June 24, 2014 Well that's the problem with shared manuals. Depends where you look. There was one Charger 12 model 1-0402 in 1972 that used the 8362 ignition switch like you should have. They did add a solenoid and that may be because of the clutch pedal safety switch but that is a good idea to save the ignition switch. They are expensive because they carry the whole starter load without a solenoid. This 1-0402 wiring diagram should work for you If you don't have the clutch switch the starter wire will go directly to the starter and be a heavy #6 or #8 wire as will the wire bringing power to the switch from the battery. Garry Share this post Link to post Share on other sites
