Sparky-(Admin) 25,974 #1 Posted June 17, 2014 A buddy needs the part I have circled in red and for the life of me I have no idea what its called. And can it be bought separately? I don't see any parts places offering it by itself. It has to have the clip so that the socket can be removed from the ball, not the fixed type. Thanks, Mike.......... Share this post Link to post Share on other sites
squonk 47,455 #2 Posted June 17, 2014 (edited) I would call it a throttle rod and you might find one at the show. One guy usually has a pile of carbs. You may need to buy a whole carb but if it's needed so what. Edited June 17, 2014 by squonk Share this post Link to post Share on other sites
pacer 3,180 #3 Posted June 17, 2014 "All Metal, Early Style Throttle Linkage Assembly with Integrated Ball w/Threaded Stud." On Brian Millers site--- a bit pricey.... http://gardentractorpullingtips.com/a1miller.htm Share this post Link to post Share on other sites
Sparky-(Admin) 25,974 #4 Posted June 17, 2014 "All Metal, Early Style Throttle Linkage Assembly with Integrated Ball w/Threaded Stud." On Brian Millers site--- a bit pricey.... Close, but it cant be the integrated type. His carb has the ball attached and its non-removable. Mike........... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,376 #5 Posted June 17, 2014 Found one in a K341 parts manual Group 17 and all the parts are separate Ball joint rod Ball joint body Kohler K341 16HP PL Spec 71105-71384 TP-983-B Garry Share this post Link to post Share on other sites
wallfish 20,242 #6 Posted June 17, 2014 Close, but it cant be the integrated type. His carb has the ball attached and its non-removable. Mike........... It can be removed with a small grinder or a file if you only find the integrated type. Share this post Link to post Share on other sites
racinfool40 203 #7 Posted June 17, 2014 Got ya covered..See ya at the show... Share this post Link to post Share on other sites
pacer 3,180 #8 Posted June 17, 2014 It can be removed with a small grinder or a file if you only find the integrated type. Yep, couple minutes with a Dremel and its off - I've done a couple like that. Share this post Link to post Share on other sites
