JERSEYHAWG / Glenn 4,589 #1 Posted June 15, 2014 I might as well replace the front wheel bearings on the 854. I thought about using the flanged bearing that is open on the inside. would you fellas use the flanged bearing? Or does the flange add to much width? Or would you just use bearings that seat flush with the rim? I thought the flanged bearing being more heavy duty would be better. thanks guys, Glenn Share this post Link to post Share on other sites
rmaynard 17,556 #2 Posted June 15, 2014 The 854 uses the standard flanged bearing 1-3/8" OD x 3/4" ID, Toro number 110513 1 Share this post Link to post Share on other sites
