WH nut 553 #1 Posted June 12, 2014 (edited) Ok, Im having troubles deciphering the belt guide. I have a 36in SD deck I needing a drive belt for (PTO) I use this deck on my 310 and B80. I know it uses a different belt between the 2. Im looking for the one for the 310. Any Help? Need number and length. Edited June 12, 2014 by WH nut Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,473 #2 Posted June 12, 2014 The 310-8 used a 36" rear discharge and a 37" side discharge only? How many blades on it? 2 or 3? Garry Share this post Link to post Share on other sites
WH nut 553 #3 Posted June 12, 2014 This is an older 3 blade deck that I switch around between tractors. The belt for the 310 is longer than the B80 or C81 I use it on. I have no idea what model the deck is for sure. Mid 70s? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,473 #4 Posted June 12, 2014 Try using deck model number 05-36MS02 Drive belt 102741 {HA/Ax96.6"} 1/2" x 96.6" Garry Share this post Link to post Share on other sites
WH nut 553 #5 Posted June 12, 2014 Thanks Garry, the tractor is at my sweeties and I was hoping to pick up a belt before I run over there. I have 6 or 8 mule drives and I just grab one that fits and never paid any attention to belt numbers. Share this post Link to post Share on other sites
