Vinylguy 4,797 #1 Posted June 11, 2014 I am thinking the 211-3 hoods are the same dimensions as the 3 and 4 hundred series tractors. can anyone confirm this? Thanks in advance. Share this post Link to post Share on other sites
slammer302 2,157 #2 Posted June 11, 2014 From what I can see yes they are Share this post Link to post Share on other sites
JackC 619 #3 Posted June 13, 2014 I have both. I will try to remember to check over the weekend. Share this post Link to post Share on other sites
Vinylguy 4,797 #4 Posted June 13, 2014 Thanks Jack. I an pretty sure they are but have to know for sure. Share this post Link to post Share on other sites
JackC 619 #5 Posted June 15, 2014 The 211-3 is a smaller machine than a 300/400 Series. The hood is about 2 inches shorter. The length along the bottom of the 211-3 hood decal is about 24 inches and the height at the front of the decal is about 21/4 inches. The same measurements for the decals on the hood of the 400 series are about 26 1/4 to 26 1/2 by 2 3/8 depending on year. If you need more precise measurements to make decals for the 211-3 let me know and I will take pictures with a tape against the decals. Share this post Link to post Share on other sites
Vinylguy 4,797 #6 Posted June 15, 2014 The 211-3 is a smaller machine than a 300/400 Series. The hood is about 2 inches shorter. The length along the bottom of the 211-3 hood decal is about 24 inches and the height at the front of the decal is about 21/4 inches. The same measurements for the decals on the hood of the 400 series are about 26 1/4 to 26 1/2 by 2 3/8 depending on year. If you need more precise measurements to make decals for the 211-3 let me know and I will take pictures with a tape against the decals. I have made a few adjustments to the dimensions Jack. According to your dimensions the front hood decal that wraps around the nose of the hoods would also be a bit smaller so I adjusted it also. Check my dimensions against your originals when you get time. I am busy trying to prepare for the show and am far behind where I want to be so this is not a top priority but have been getting more requests for these models lately and would like to be able to offer a set for them that is as close to OEM as possible. Thanks for your help. Share this post Link to post Share on other sites
JackC 619 #7 Posted June 16, 2014 Here are some crude pictures: Share this post Link to post Share on other sites
SousaKerry 503 #8 Posted June 16, 2014 Don't forget the WorkHorse LT-1100's as well first machines to use this style hood. Share this post Link to post Share on other sites
Vinylguy 4,797 #9 Posted June 17, 2014 I am pretty confident that these will work. Assuming the rear fender seat pan is the same? Share this post Link to post Share on other sites
