j main 5 #1 Posted June 10, 2014 Hi Guys Im a noobie so plz bare with me I have a Raider 10 6 speed tranny.My question is where is the drain plug on the tranny? also what fluid goes in it brand -weight ect I want to change the trans fluid becuse im sure it hasent been done lol. Thank you for all the help Jeff Main Share this post Link to post Share on other sites
stevasaurus 23,419 #2 Posted June 10, 2014 Jeff...welcome to Red Square. should be a drain plug on the bottom of the trans...guessing, but probably an Allen head set screw...when you find it make sure you clean it out good so as not to strip where the wrench goes. I would use 90 wt oil (about 1 1/2 qts)...the manual may call for 10w30...without looking at the manual, I would do the 90 wt. Let us know what the oil looks like when you drain it...may want to flush it out first. Share this post Link to post Share on other sites
j main 5 #3 Posted June 11, 2014 Thank you for the help Jeff Share this post Link to post Share on other sites
