Digger 66 3,523 #1 Posted June 6, 2014 Hey boys & girls , going to pick up my moms el-cheapo Poulan tractor tomorrow morning to address a problem . Seems the tractor does everything great but go into reverse . Just wondering if any of you had any experience with this particular model ? Apparently the shifter does not fully go into the reverse part of the shift gate . I've done some www searching but no concrete answers could be found . Share this post Link to post Share on other sites
shallowwatersailor 3,220 #2 Posted June 7, 2014 Here is a link for the OM. That would be a start. It seems to be a common complaint to not go in reverse. It has a friction wheel and I assume drives like a walk-behind snowthrower with a friction wheel. ??? http://inteli-rider.poulanpro.com/resources/PB30_manual.pdf Share this post Link to post Share on other sites
Digger 66 3,523 #3 Posted June 7, 2014 Thank you very much for the reply , talked to mom last night & it may be covered under warranty a second time after a shop "fixed" the same problem a while ago . This one's on hold for now ... Will post the outcome . Share this post Link to post Share on other sites
