Crankyfred 5 #1 Posted June 6, 2014 I guess i am going to find out just how much of a Wheel Horse fan i am. I went out the other day to sift through the parts i have so far for the rj. First thing i noticed was someone hacked up the hood- steering support. So off to tractor supply to fetch a piece of flatstock to fix it right. I cut off the pieces to weld on the new ones and already have a question for you fine horse-a-holics. on the rj58 are the upright pieces the attach to the hood support 90 degrees off the frame? and who is the round hood parts guy? i think i am going to need to put him on speed dial. Share this post Link to post Share on other sites
stevasaurus 23,619 #2 Posted June 7, 2014 At the moment, I would try to get a hold of SmokinJoe (member on this site)...send him a PM. I see you are in the US...so is he...Illinois. If you are in central U.S...this could be easy for you. BTW...welcome to Red Square. Share this post Link to post Share on other sites
953 nut 64,272 #3 Posted June 7, 2014 Sounds like you are diving into a big little project, remember to keep us posted and Share this post Link to post Share on other sites
AMC RULES 37,254 #4 Posted June 7, 2014 (edited) I've included here a couple of bare RJ frame picts for you to reference. (Clink on them to enlarge) Edited June 7, 2014 by AMC RULES Share this post Link to post Share on other sites
buckrancher 2,695 #5 Posted June 7, 2014 and yes to your question the supports are 90 degrees from frame Brian Share this post Link to post Share on other sites
Crankyfred 5 #6 Posted June 7, 2014 Thank you for all the info......I am not sure if any part of this thing is good! but i refuse to let it go for scrap so it will eventually be put back together. I will post some pics at some point. The hood has been repaired by po and i am missing the gear shift so far. no front tires and a couple extra pieces welded to the frame. it wont be a perfect show horse but will look good in my yard!! Thanks again 1 Share this post Link to post Share on other sites
Crankyfred 5 #7 Posted June 8, 2014 (edited) Thanks for the pictures......Now i am thinking not only did someone hack up the frame but it may not be an rj frame at all. where my steering shaft goes in at the bottom it is bent under the frame......It is getting dark but i will try and get a Picture. Edited June 8, 2014 by Crankyfred Share this post Link to post Share on other sites
