Crabtreeb 8 #1 Posted June 6, 2014 I am rebuilding a 1974 B80 with the 5084 tran axle is there any one out there who knows the cross over numbers for the seals, bearings,gaskets, any help will be great fully appreciated. Share this post Link to post Share on other sites
AMC RULES 37,196 #2 Posted June 6, 2014 Maybe this will help. Share this post Link to post Share on other sites
rmaynard 16,290 #3 Posted June 6, 2014 Just did a 4 speed and the Toro and generic part number are: 1" Axle seals and brake shaft seal, Toro #100863, generic CR-9815 Input shaft, Toro #100441, generic CR-7410 Gasket, Toro #3912 Share this post Link to post Share on other sites
Crabtreeb 8 #4 Posted June 7, 2014 Thank you both any one got the numbers on the needle bearing fot the axle i don't see my trans in the PDFs allso how do you become a financial supporter of this site it has bin verry helpful. Share this post Link to post Share on other sites
rmaynard 16,290 #5 Posted June 7, 2014 At the top of the page is a section called "store". You can purchase your membership there. The axle needle bearings are Toro #1528. They cross to a Torrington B-1616. Share this post Link to post Share on other sites
stevasaurus 23,274 #6 Posted June 8, 2014 You want the PDF #2 which is for 3 and 4 speed transmissions. Share this post Link to post Share on other sites
Crabtreeb 8 #7 Posted June 8, 2014 Thanks for all the info this is such a great site. Share this post Link to post Share on other sites
