Scotsman 46 #1 Posted June 5, 2014 I was thinking of picking up a 516 H But a knowledgable friend warned me of a overheating issue with the hydro. He said ones with bad trannies overheat,and it is a big problem. So does anyone know of any issuies? Share this post Link to post Share on other sites
Kelly 1,037 #2 Posted June 5, 2014 Not sure about the over heating, but the eaton 700 had a bad rep for being a weak trans, not built to use ground engaging attachments, like a bottom plow, tiller, and really as old as they are getting snow plows and rollers. buy with caution. Share this post Link to post Share on other sites
boovuc 1,090 #3 Posted June 5, 2014 As Kelly stated! The Eaton 700 is a big weak link. The 520-H uses the Eaton 1100 rear and it is many many times better than the 700 Eaton. The Eaton 700 didn't overheat that I knew of. It just wasn't designed to be used on a heavy duty garden tractor like the 500 series. Share this post Link to post Share on other sites
Scotsman 46 #4 Posted June 5, 2014 Thanks for the tips. It was exactly what I was afraid of. I appreciate it guys. It's too bad because it came with a 2 stage aftermarket snowblower, Wheel weights, Chains, And 5 tombstone weights. All for 600$ It seemed to good to be true, and I guess it was. Share this post Link to post Share on other sites
squonk 45,591 #5 Posted June 5, 2014 If that's a Berco blower, buy it anyway sell the tractor and look for something with an 1100 Share this post Link to post Share on other sites
Scotsman 46 #6 Posted June 5, 2014 (edited) This is it. It sure looks nice don't it Edited June 5, 2014 by Scotsman 1 Share this post Link to post Share on other sites
wrmhaste 235 #7 Posted June 5, 2014 For that price it would be worth it in my opinion. Take the weights,chains and blower off. Clean the tractor up nice and sell it separate. You should be able to get 6 out of the tractor. Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,528 #8 Posted June 5, 2014 It sure looks nice and has everything but the right trans. Those suitcase weights look boss. Glenn Share this post Link to post Share on other sites
squonk 45,591 #9 Posted June 5, 2014 I just bought a set of those exact same weights! Share this post Link to post Share on other sites
Forest Road 595 #10 Posted June 5, 2014 $600 sounds good! I have a completely rebuilt factory WH 2 stage. In my opinion they're very poorly constructed. I've seen a few Berco blowers on other machines and they appear to be built much better. I hear that they throw snow quite a bit further too. Share this post Link to post Share on other sites
Kelly 1,037 #11 Posted June 5, 2014 Blower if nice with the weights and chains come winter in my area is a $500+ set up, the tractor if runs good looks to be a $300 machine, offer $500 run it till the trans dies swap in a 1100 unit or buy a bigger machine with a 1100 in it. 1 Share this post Link to post Share on other sites
jdleach 525 #12 Posted June 5, 2014 (edited) Blower if nice with the weights and chains come winter in my area is a $500+ set up, the tractor if runs good looks to be a $300 machine, offer $500 run it till the trans dies swap in a 1100 unit or buy a bigger machine with a 1100 in it. That was my thinking. If all else is good (the cosmetic and rust issues are pretty easily rectified), scrag the tranny, and pop in an 1100, or 8-speed with the 1 1/8" axles. If you are remotely mechanically declined (you have to be declined in some manner if you like working on greasy stuff ), the swap out is pretty straightforward. I would snagged it in a New York minute. Edited June 5, 2014 by jdleach Share this post Link to post Share on other sites
wrmhaste 235 #13 Posted June 5, 2014 Blower if nice with the weights and chains come winter in my area is a $500+ set up, the tractor if runs good looks to be a $300 machine, offer $500 run it till the trans dies swap in a 1100 unit or buy a bigger machine with a 1100 in it. $300 machine???? I want to move out that way. Around my area (upstate ny) I can't touch that machine for less than a grand. And even then it's not in as good of shape. Share this post Link to post Share on other sites
Kelly 1,037 #14 Posted June 5, 2014 $300 for the bare tractor, no attachments, and it looks kinda ruff, from the pic. Share this post Link to post Share on other sites
AMC RULES 37,254 #15 Posted June 5, 2014 Looks like a good deal to me. Eaton 1100's aren't too hard to find. Share this post Link to post Share on other sites
wrmhaste 235 #16 Posted June 5, 2014 $300 for the bare tractor, no attachments, and it looks kinda ruff, from the pic. Even still bare tractor here of that size is a grand. With the attachments people are asking 2k on average. That's why it's taken me over 10 years to get mine and I stumbled into my deal. Share this post Link to post Share on other sites
boovuc 1,090 #17 Posted June 6, 2014 Buy it. (If it's still available). The Berco, the weights and the engine are well worth it. Share this post Link to post Share on other sites
leeave96 496 #18 Posted June 6, 2014 I'd say buy it and run it. If the tranny fails you can swap in an Eaton 1100. Pretty good deal IMHO. Share this post Link to post Share on other sites
546cowboy 302 #19 Posted June 6, 2014 I had 516H for 5 or 6 years and used it for mowing and never had a problem. From the looks of that tractor a guy would just be asking for trouble from a 700 tranny. I do have a 700 pump for sale. I got into 520's while I had the 516 and just couldn't go back to the 516. Share this post Link to post Share on other sites
PaulC 342 #20 Posted June 6, 2014 I have a 1987 312-A with the eaton 700. Tractor has 1172 hrs on it and the trans still works great. I was told it was used to mow 3-4 acre lot for most of its life. All I use it for was mowing and blowing snow and its really smooth and works great. As long as you are pretty confident it wasn't used improperly for rototilling etc and it seems to work properly I wouldn't be scared of it. Share this post Link to post Share on other sites
boovuc 1,090 #21 Posted June 7, 2014 Scotsman! Were you able to get the package or was it sold? Let us know. PS....your not that guy that keeps saying "feed it" are you? Share this post Link to post Share on other sites
Scotsman 46 #22 Posted June 8, 2014 I didn't buy it. I heard alot of conflicting opinions, but most seemed to generaly be saying buy it and swap the tranny. If someone want to know where it is, i will let them know. The guy wanted 900$ with a mowing deck included, but the 600$ he ageed to sell it to me for was without the deck. Thanks everyone for the advice. I am a seeing 418-A for 400$ so I might be checking that out soon. Share this post Link to post Share on other sites
Scotsman 46 #23 Posted June 11, 2014 What do you guys think of this for 400$ b/o ? It looks awesome, but it was a one year only, Is there any problems with these that you guys know of? Share this post Link to post Share on other sites
Scotsman 46 #24 Posted June 11, 2014 Boovuc it took me reading that post 3 or 4 times before I got the feed it joke! That's too funny, And yes that actually is me. No not really. Share this post Link to post Share on other sites
Scotsman 46 #25 Posted June 14, 2014 (edited) Well I couldn't wait for the sun to come up to take a decent picture, I was so excited! But I bought a 418-A My first venture into the world of hydro. Not the one in the picture from the previous post,that one was gone. But this is a 418-A with a 48 inch mowing deck. Has a nice hydraulic lift. I am pleased. What do you guys think? I am putting the deck up for sale. The guy said it was a 48" but I didn't measure it yet. Anybody want to trade me a snowblower attachment? and some weights for the deck? Let me know,I live near Boston. Edited June 15, 2014 by Scotsman 1 Share this post Link to post Share on other sites
