ipperwash 74 #1 Posted September 25, 2008 Hi can any one help with this i have a 1277 hydro stat with manual lift and want to put a hyd lift on i have the hoses lift control and cylinder what do i have to the hydro stst trans to make it work Has any got the parts or part no Thank,s Doug. Share this post Link to post Share on other sites
Sarge 3,465 #2 Posted September 26, 2008 You'll need a couple of springs , a plunger valve and some other parts that go in the hydro's valve body . Look up the type of cylinder you have (mine has a HY-6) at Toro's web site and it lists the parts needed . I could only find the one spring , o-ring and a spacer for mine , had to rob parts out of another hydro to make it work . Sarge Share this post Link to post Share on other sites
