Dhodge 528 #1 Posted June 4, 2014 I have a model 01506 serial 785818 that I cannot find on the master model list. Can anyone else help? It does not have the typical uni drive rear end in it either. Thanks fella's Share this post Link to post Share on other sites
KC9KAS 4,744 #2 Posted June 4, 2014 I couldn't find anything like 0-1506 either....Are you sure the numbers you posted are correct and correct order? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,764 #3 Posted June 4, 2014 The model number may be 1-0150 and the 6 on the end tells us it is a 1971 model. 6-5=1=1971. Garry Share this post Link to post Share on other sites
Kelly 1,033 #4 Posted June 4, 2014 Sounds like Garry may have it, the 800 special does not use the uni drive, it has a peerless trans, with a briggs engine. Share this post Link to post Share on other sites
Dhodge 528 #5 Posted June 4, 2014 I must have had dyslexia for a moment. You guys are awesome! I knew you could figure things out for a bassackwards guy like myself. Thanks a million!!! Share this post Link to post Share on other sites
