redidbull 54 #1 Posted June 3, 2014 I bought one of these a few years back. http://www.tractordata.com/lawn-tractors/000/4/8/484-wheel-horse-lawn-ranger.html I am starting to do work to the engine and have found that it probably needs some type of new ignition. I also have been having trouble with the linkage for the carb. Question is should I just look for a replacement engine of some sort or rebuild this Tech that is there? I am sure a vert shaft engine shouldn't be too hard to come by. Thanks for any help. Jim 1 Share this post Link to post Share on other sites
SousaKerry 503 #2 Posted June 3, 2014 If it were me I would save the headaches of dealing with the Tecumseh and go with a more modern replacement, unless you want to keep it original. The ignition on a Tecumseh can be a rotten *$(@)&^$%er to deal with and parts are scarce. If it needs more then points and a condenser the cut your losses. I started acquiring a couple of parts engines to supply the couple that I have but the more I deal with them the more I am starting to dislike them. Share this post Link to post Share on other sites
redidbull 54 #3 Posted June 3, 2014 I was thinking that to. I looked at Harbor Freight but they only have a 5.5 Vert shaft. Not sure if that is enough power. I think I will go and see if the lawn mower shop has anything for sale. Thanks. Jim Share this post Link to post Share on other sites
Desko 624 #4 Posted June 3, 2014 Put a Briggs in it they'll last alot longer than those clones Share this post Link to post Share on other sites
redidbull 54 #5 Posted June 3, 2014 Thanks on the recommendation. Before I start searching is there anyone who has a vert B&S they would like to sell? I would like at least 5.5hp. Thanks. Jim Share this post Link to post Share on other sites
zelinadc 0 #6 Posted June 6, 2014 I used a Briggs and Stratton 15T212-0160-F8 1150 Series Intek PowerBuilt 11.50 Gross Torque Engine with A 1-Inch Diameter by 2-7/8-Inch Length Crankshaft, Keyway, and 3/8-24 Tapped, $270 from Amazon. The only issue was I had to make a custom exhaust and fuel tank bracket to use the original tank and have the filler come through the original hole in the hood Share this post Link to post Share on other sites
Desko 624 #7 Posted June 6, 2014 You can find good used ones and if you need parts just go to repairclinic.com Share this post Link to post Share on other sites
scWHhauler 96 #8 Posted June 6, 2014 I would look at troybuilt tillers some of them have 5hp L blocks plus electric start and ar fairly cheep to buy. Share this post Link to post Share on other sites
redidbull 54 #9 Posted June 6, 2014 I found a 4.5hp from a local guy for ~$75. Is that a good price for a good running Briggs? Thanks. Jim Share this post Link to post Share on other sites
Desko 624 #10 Posted June 6, 2014 I'd say its an OK price throw him an offer of $50 and would be even better Good Luck! Share this post Link to post Share on other sites
redidbull 54 #11 Posted June 6, 2014 He said I can have it for $30. Hope it is as advertised. Thanks. Jim Share this post Link to post Share on other sites
redidbull 54 #12 Posted June 8, 2014 I got the engine yesterday and mounted it to the tractor. The shaft is the wrong size so I will need new pulleys.A couple question:. This engine doesn't have a tradition throttle. It is from a lawn mower that has the throttle tied to the governor I believe.Should I leave it like that? It also has the safety handle on off.hat should I do with that? The engine ran for a second til the clamp I used to hold the safety handle switch. Weird thing is it kinda snapped back when I pulled it like it back fired. I have never had that happen. Can these engines be run with out a blade/load? I thought I had heard that. This engine has not been maintained and it made need a good clean up. Thanks for any help. Jim Share this post Link to post Share on other sites
Desko 624 #13 Posted June 8, 2014 Well of its off a push mower then it has an aluminum flywheel so yes there should be a blade to balance it since its on a tractor you will need a cast iron fly wheel from a 3hp Briggs or a 5hp Share this post Link to post Share on other sites
redidbull 54 #14 Posted June 8, 2014 So this will not work? Thanks. Jim Share this post Link to post Share on other sites
Desko 624 #15 Posted June 8, 2014 Not without a cast iron flywheel. Share this post Link to post Share on other sites
redidbull 54 #16 Posted June 8, 2014 Would having the pulleys on the shaft make any difference?There are 2 and they are heavy. Act kinda like the blade? Thanks. Jim Share this post Link to post Share on other sites
Desko 624 #17 Posted June 8, 2014 No sorry it won't work as they don't create balance. Share this post Link to post Share on other sites
redidbull 54 #18 Posted June 8, 2014 Thanks for the help. I guess my next move is to find an engine with a "heavy" flywheel? Jim Share this post Link to post Share on other sites
Foozerush 40 #19 Posted June 9, 2014 I repowered my tiller with a HF $99 6.5hp, runs fine, seen people use them on round hoods, I say go that route, then rebuild the Techy if you want it original. That's what I would use if I had an older horse that needs an engine. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
redidbull 54 #20 Posted June 9, 2014 Is the HB vert a heavy flywheel or am I going to have the same problem if I do that? The tech is going bye bye. I will probably offer it up for parts. It was always hard to start, but ran good once it was going. Also the throttle linkage was a PITA. Jim Share this post Link to post Share on other sites
Foozerush 40 #21 Posted June 9, 2014 Don't know if it is, but like I said I've seen quite a few pics of guys using them on tractors, not just WH's..... And mowing and pushing snow, so I'm sure that the flywheel can handle the pressure you throw at it.... Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
redidbull 54 #22 Posted August 19, 2014 I've been away from here for a while with other projects and my job search. If anyone local here in Ct knows of anyone hiring electronic techs, assemblers,electro mechanical assemblers etc please let me know. Anyway I was thinking of just getting rid of my 69 WH but I can't seem to do it. So I went to Amazon and found this. http://www.amazon.co...=heavy flywheel I am pretty sure this will work Please let me know if it will. Thanks. Jim Share this post Link to post Share on other sites
Theroundhousernr 590 #23 Posted August 19, 2014 That is a vertical shaft motor. Not going to work in your ranger.... Sorry Share this post Link to post Share on other sites
CasualObserver 3,411 #24 Posted August 19, 2014 He has the later vertical shaft ranger. Click the link in the first post. Share this post Link to post Share on other sites
Theroundhousernr 590 #25 Posted August 19, 2014 OHHH stupid me . I missed that link and I was wondering about the talk of using a lawn mower motor... Share this post Link to post Share on other sites
