leeave96 496 #1 Posted May 29, 2014 Anyone know offhand what the rim offset was/is for the 8.5, 9.5 and 10 inch wide rear wheels on the 300/400/500 series tractors? I assume the C-series would have been the same? Thanks! Bill Share this post Link to post Share on other sites
Kelly 1,038 #2 Posted May 31, 2014 Well the widest rear wheel stock with the 5 bolt pattern for a WH is 8.5" most common is the 7" on most C series and more, with out checking I think back spacing is around 2.5" but not all of them are the same, it varies from rim size to rim size. Share this post Link to post Share on other sites
Martin 2,135 #3 Posted May 31, 2014 I can check, but from what i came across when i picked up the 416 tractors, is the later ( have a 92 and 2 95s) 7 inch wide wheels had less dish on the outside than the 60-70s 7 inch wheels. the center was more in the center of the rim than the earlier 7 which was fixed more toward the inside of the rim. Share this post Link to post Share on other sites
