leeave96
Quick Rim Offset Question
leeave96
Anyone know offhand what the rim offset was/is for the 8.5, 9.5 and 10 inch wide rear wheels on the 300/400/500 series tractors?
I assume the C-series would have been the same?
Thanks!
Bill
Kelly
Well the widest rear wheel stock with the 5 bolt pattern for a WH is 8.5" most common is the 7" on most C series and more, with out checking I think back spacing is around 2.5" but not all of them are the same, it varies from rim size to rim size.
Martin
I can check, but from what i came across when i picked up the 416 tractors, is the later ( have a 92 and 2 95s) 7 inch wide wheels had less dish on the outside than the 60-70s 7 inch wheels. the center was more in the center of the rim than the earlier 7 which was fixed more toward the inside of the rim.
