papasan1 4 #1 Posted May 27, 2014 I cleaned out the fuel tank and started blowing out the lines from rear to frone. I blew air into the output line from the pump and now it's not pumping. Did I mess it up or am I missing something? Thanks Share this post Link to post Share on other sites
papasan1 4 #2 Posted May 27, 2014 Never mind, I'm an idiot. I got the pump working then it would not run. I had the float assembly cockeyed in the carb. Running good again. Share this post Link to post Share on other sites
papasan1 4 #3 Posted November 17, 2014 Since this post, the fuel pump failed. Replaced with the Napa one mentioned on the posts here. Mounted it just below the OEM pump with self drilling screws. Wired it into the ignition switch, plugged the OEM ports and it works perfectly Thanks for all the good posts. Frank Share this post Link to post Share on other sites
